Lost tach and fuel gauge for no aparent reason....
Old 03-22-07, 08:13 AM
M34LNCH
M34LNCH's Avatar
Default Lost tach and fuel gauge for no aparent reason....
OK here is the deal guys, my car has an aristo swap in it with an extended aristo harness, drove the car for months like that with no issues, all electronics worked fine. I just sort of went crazy with it and did a single turbo, fuel system, intake manifold etc...and installed an AEM in it. The tach was working just fine on the car for a couple of days, and then out of the blue it doesn't work anymore, together with the fuel level gauge, and there has not been any work performed since.
I took cluster off make sure the resistor bridge is still in place, checked all the plugs behind the dash and its fine, but i'm sort of out of ideas on where to check next. Oh also if i plug the AEM to my labtop I can read the tach signal there just not on the dash. BTW all lights and temp gauge work just fine.
Thanks.
Old 03-22-07, 08:51 AM
sc250tt
sc250tt's Avatar
did you ground the fuel signal wire on the harness? did you do the tach mod ? if not thats your problem
Old 03-22-07, 09:04 AM
M34LNCH
M34LNCH's Avatar
Default ...
AS I stated the tach mod was performend when the swap was originally done and it worked fine then, and fuel sending unit retains the harness intact. THe car had the RPM working perfect with the AEM and everything in place for a couple of days. I cranked it last wednsay and thursday and tit worked just fine, car stayed in the lift then on friday i went to start it and no RPM just like that.
Old 03-22-07, 12:38 PM
sc250tt
sc250tt's Avatar
wow thats weird .try switching out clusters .my sc 400 did the same thing when i did the swap but a hard slap on the dash usually fixed it .goodluck tho
Old 03-22-07, 05:38 PM
craaaazzy
craaaazzy's Avatar
what is this tach mod? and why the need to do it? tia
Old 03-22-07, 07:06 PM
M34LNCH
M34LNCH's Avatar
search is your friend
Old 03-23-07, 09:24 AM
craaaazzy
craaaazzy's Avatar
thanks, have done so.
bibimartin
RX - 1st Gen (1999-2003)
01-05-18 10:22 AM
Biggu
SC- 1st Gen (1992-2000)
02-21-14 07:20 AM
SoupFlies
03-29-13 11:49 AM
jrbell3
12-09-09 05:18 PM
SH_JZZ30
02-20-09 12:42 AM
Quick Reply: Lost tach and fuel gauge for no aparent reason....
