Pulling the engine code???
Old 03-02-07, 09:02 AM
babyduke
babyduke's Avatar
Default Pulling the engine code???
I know little about cars. What does "pulling the engine code" mean?
Old 03-02-07, 11:15 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
When you have a Check Engine light, finding out what the error is.
Old 03-02-07, 01:16 PM
babyduke
babyduke's Avatar
How do you do that w/o taking it to the shop?
Old 03-02-07, 01:35 PM
Sc400Red95
Sc400Red95's Avatar
you have to use a little bit of wire. and jump the 2 connectors in the DIAGNOSE(spelling) i believe it's T1 and E1. The connector is located on the intake side of the 1j. Not 100% sure if it's in the same location as a 2j or 1u.
Old 03-02-07, 01:49 PM
babyduke
babyduke's Avatar
Do u know where in the engine these are located?
Old 03-02-07, 09:30 PM
vwynn
vwynn's Avatar
theres another trick u can do.. i dont know if its as usefull as doing that way stated up ^^..
but i guess u can try it.. i believe u press and hold AC and recirculate and then turn on the car (not engine)
then it does stuff.. iono wat it means but.
mine says
11 (Beep)
21 (Beep)
23 (Beep)
41 (no beeP)
Old 03-05-07, 06:56 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
Not in the engine. In the diagnostic port under the dash, drivers side.
Try here:
http://www.troublecodes.net/Lexus/
TriniLex
02-18-17 07:42 AM
aceboogie6
GS - 1st Gen (1993-1997)
02-13-11 10:28 PM
Herm
10-31-07 06:00 AM
V8Cressida
06-06-02 09:51 PM
Quick Reply: Pulling the engine code???
