HELP with 1JZ Car won't go above 2k RPMS and crappy idle
Old 02-18-07, 02:11 PM
shern
shern's Avatar
Default HELP with 1JZ Car won't go above 2k RPMS and crappy idle
UPDATE:
The car seems to be running okay. Chalk it up to a wet air filter....I think. We'll see how she runs from now on.
Ok Folks
I have a 93 SC300 5spd with a 1JZ swap. I removed the battery today to do some cleaning of the inner fender wells, nothing on the motor. After putting the battery back in, the car took a while to start.
It turned over a bunch of times before finally kicking in. After the car started up, the idle was pretty low. When I tried to rev it up, the car engine would rev limit at 2000 rpms. If I let off the gas at that point, the engine would drop to idle, somtimes dropping below idle.
What would cause the 2k rev limiter? Limp mode?
Steve
estomax
05-16-14 07:31 PM
4urxtc
01-08-11 03:59 PM
attzor
09-28-09 09:53 PM
1jhazzard
03-02-07 05:41 PM
Quick Reply: HELP with 1JZ Car won't go above 2k RPMS and crappy idle
