Manual Trans Whine???
OK so I have a '94 5Spd that is really starting to give me a headache. My problem is that in 1st, 2nd, and 3rd gear my trans sounds like it has straight cut gears. Then on top of that it doesn't want to go into gear 1st as smooth as it should (takes some force and down shifting is kinda impossible) Which is annoying becuase I have no idea what it might be. I have swapped out the fluid and I don't think that is it. I'm thinking that after all this time in trying to find a 5spd, I have found the biggest peice of junk. I think my trans is on it's way out.
sounds like your trans is dead.. check your fluid level. this has happend to me before when i ran out of tranmission fluid.. most likely your gonna need a rebuild or new trans. it make any noise in 4th gear?
Maintenance Moderator
A friend experienced this same issue with his EVO after a hard launch that got some wheelhop... sounded like straight cut gears 1-2... When he had it rebuilt, one of the important gears had been ground down, and was not making 100% contact with the other gears... he had to have the trans rebuilt and the necessary stuff replaced...
Noahhjones
08-19-16 04:11 PM
