trac light problems
trac light problems
My track off and check engine light have been coming on at random and turing off 10 min later about 3 times now. Not real sure here, checked erything out in the engine, everything seems ok. Now today driving home the trac light on the speedometer comes on and stays on.
On the answer I found from the search it could be the following,
o2 sensor
some of the lines coming lose....
Seems like heavy rain activated the check engine light and trac off light the first time.
I am stuck now. Anything else that could be a problem that I should look at?
o2 sensor
Disconnect your Neg. Bat terminal for about 15 seconds.
You might have a broken Track wire. If it has flexed too much then the wire might be frayed inside the insulation.
CheVelleSS
Performance & Maintenance
12-14-13 03:30 PM
Jasoneo5
03-06-04 02:55 PM
