Supra 6spd LSD into SC300
Old 10-30-06, 06:41 PM
757jetip
757jetip's Avatar
Default Supra 6spd LSD into SC300
Does anyone know if you need to use the Supra output shafts with this swap? I keep trying to search but the darn search function keeps saying no items found for some reason.... I heard that the SC400 driveshaft is a direct fit when you put in the six speed, but that is all I can find at the moment.
Thanks.
Old 10-30-06, 08:17 PM
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
Thanks.
No, it's a direct swap with auto transmission.
Chris
Old 10-30-06, 08:22 PM
95 Integra
95 Integra's Avatar
Chris
Incase this is unclear to anyway, hes saying the TT auto diff is a direct swap....not that the 6spd diff is a direct swap w/ the SC300 auto. Either way, the driveshaft is a different length and the drivers axle is a different length (I believe thats correct, one of them is the same, the other is not).
Old 10-31-06, 08:12 PM
TT6SPDSC
TT6SPDSC's Avatar
You'll need the complete 6 speed differential assy and the 6 speed left axle.
As for a DS I HIGHLY reccomend getting a one peicer made. If you're hooking with any respectable power you'll twist the stocker like a pretzel. If you're spending the $$ on the 6 speed diff then I would expect that you can afford to spend the little bit of extra coin on a nice aluminum ds. You'll be glad you did as it decreases rotational mass and you CAN feel the difference.
Old 11-01-06, 06:51 AM
sao1
sao1's Avatar
Hmmm... 3.13 gears and TH400 Tranny. Has anyone experienced this?
angus
Performance
07-14-14 07:29 PM
outlaw0209
SC- 1st Gen (1992-2000)
08-20-10 05:45 PM
lisc300
07-07-10 08:45 AM
simann
02-19-07 07:18 PM
Quick Reply: Supra 6spd LSD into SC300
