My baby's in trouble please help!!!
Well, all of the sudden my sc300 started making a crap load more noise. It sounds like a truck . At first I thought it was maybe a clogged maf. So I took the entire intake apart and cleaned everything. Still making tons of noise.
It has been about a week now and the car continues to make a really loud wind like noise at startup and while driving. Sounds really similar to a public bus minus the turbo spool. The car also seems to make a little squeeling noise at high rpms (5000+) and losses power drastically. My second guess to what might be wrong is the fan clutch but not 100%.
I have searched and have come up with nothing regarding my situation. So, any feedback is greatly appreciated. I just want to get her back to working condition. I just ordered new parts for her too
Neu`roc´i`ty
Could be a torque converter...(not sure if your auto or manual)
Fan clutch....if it is, it will be hard as hell to move while engine is off,
Water pump....
Alternator.....
you need to have the hood open listening to the engine. Have someone else rev the engine, locate the sound
Water pump....
Alternator.....
Water pump....
Alternator.....
Water pump....
Alternator.....
Banned - could not follow forum rules
Oh, that is why the Miss..river is so blackened and murky..(rotting cars at the bottom, hmmm makes perfect sense)...My brother lives down in Columbus, Ms...I've been there and there is no cliffs to drive your insured car off of...Just flat land and a big **** dirty river....Alot of Fords and Chevy's cruising around too...
Ok new idea - Insure the lemon and start an accidental engine fire and let it burn and blow....maybe?
This is getting bad, I better stop these remarks before I get banned again..This forum is very sensitive to humor, unrelated topics, wise cracks, etc..It feels like my ***** are chopped off every time I log on to the club.....
The only difference is my fan clutch is not locked up . So im unsure if thats related, or perhaps a separate issue.
Thanks to everyone for their responses. I'm not sure if it would be an exhaust leak because then the exhaust would have been funny sounding. I do not have a twin setup, I wish I did but i dont . Just out of curiousity can everybody else move their fans when the car is off? Does it spin with ease or is ther always some sort of resistance.
O...ok well then i'm guessing it is definately the fan clutch then. The fan needs a very strong push to even move it and it will definately not make a full revolution unless I push it all the way around.
Neu`roc´i`ty
you know what....you should go electric fan then, get rid of that extra weight and centrifugal force, make ya some more power in the end.
If you are going "stock" fan replacement, its a easy fix, few bolts, bust the old one off, clean the area, bolt the new one on.
Make sure your water pump is cool, that would make a nice noise too.
But then your engine would run hotter than norm. Get a flash light and look for water/coolant leaking out the bottom of the pump.
If its your PWR steering pump, it will make noise also.
Check this by leaving the car in park, at idle. Turn the wheel L2R and the noise will increase, as fluid is used to push the steering arms. If so, check the level, add some fluid if low and drive around the block a few times. turning alot...work the fluid into the system. the noise will decrease over time if its a fluid thing.
All this is from the hip, so please don't take this to the bank!
