Blown SC300 93 Head Gasket
#31
Just to update you the head gasket had a small breach around one of the cylinders. Once we had the gasket off the breach was around the inside of the round hole on the HG. As I mentioned before when we did the gasket I used a Toyota supra one with ARP bolts because I knew I was never going to do it again. The new gasket superseded the old original one. I spent 12 Hours cleaning the top of the Block with the cylinders stuffed with Rags so nothing when into the cylinders. I cleaned the block with new razor blades and gasket remover spray until it was spotless. I had the head checked for warpage and also checked the top of the block with a straight edge used for checking for flat surfaces. It turned out perfect and I caught it just in time. It wasn't getting in the oil yet. I still have it today and it runs perfect.
#32
Thanks for updating this old thread. My '92 SC300 just blew the HG after 199K miles and the description of your problems mimicked mine almost exactly. The shop I use I trust (and they just did the HG on the wife's LS430) and hope to get many more years (as you did) on the SC....
SupraDremr
Performance & Maintenance
18
08-14-12 02:51 PM
ADAM P
12
06-06-06 08:08 AM
