Engine pics we don't normally get to see
Keeper of the light
This is for the newbs mainly. A lot of us have seen every inch of our engine. My sc400 parts car literally has no front on it right now after some sawzall work so I have a straight shot to the front of the engine and can take some nice open pics.
I figured this would be a good chance to show where some critical bolts are on things we usually end up having to work on. (A/C, Alt, etc)
So incase you have not done much work on your car, here ya go
i notice on the sc400 the tensioner has a metal pulley on the 300 it is plastic well i am not sure if they upgraded it on later models. and also the crank pulley has grooves in it as for mine 93 sc300 it does not and it is slipping. can you measure the pulley size i just want to see if they are the same diameter as a sc300 so if i upgrade i will order the stuff from a 400 instead. actually i wonder if they even have the same bolt pattern. if you can help lmk thanks.
Lexmex
RX - 1st Gen (1999-2003)
08-29-18 08:14 AM
MarcusMIA
SC- 1st Gen (1992-2000)
11-01-09 06:50 PM
