Amount of torque for oil drain plug (from factory service manual?)
Old 08-08-06, 07:28 AM
Streamline
Streamline's Avatar
Default Amount of torque for oil drain plug (from factory service manual?)
Can someone tell me the factory torque specs for the oil drain plug?
A scan of the page would be helpful as well.
(This is because of this thread: https://www.clublexus.com/forums/sho...d.php?t=231475 )
Old 08-08-06, 08:18 AM
Streamline
Streamline's Avatar
I found the torque specs all thanks to the mighty "Search" function.
https://www.clublexus.com/forums/sho...drain+plug+pan
BUT if someone can please scan the page from the factory service manual for me. That would be great.
Old 08-08-06, 08:36 AM
Tammy
Tammy's Avatar
Are you reusing or replacing the oil plug seal while tightening to a torque value.
A new seal ,thin coated with grease, tighten to 30 Ft Lbs. Used seal, 26 Ft Lbs.
In either case, always check for seepage with a flashlight a day or two after tightening.
The Lexus seal will crack and leak if tightened too tight, for your awareness.
j.tom
03-27-24 05:52 AM
VicSWFL
04-20-17 11:58 AM
Flat Four
07-19-08 02:51 PM
stiles_s
GX - 1st Gen (2004-2009)
12-01-07 03:53 PM
pimp42
03-18-03 08:44 PM
Quick Reply: Amount of torque for oil drain plug (from factory service manual?)
