not starting
not starting
I have a 93 sc300. I bought it used in the winter of 00. when summer came around, I noticed that sometimes it did not want to start. I did not think much of it becuase it eventually started. as the years went on it became worse. I took it to a mechanic who said it was the ignitor. I have since replaced it. bascically what happens is when it is very hot outside and I stop at one store, then to another, eventually it does not want to start and using the a/c makes it worse. anyone have an idea what it might be.
thanks
thanks
thanks
thanks
About 8-9 months ago I turned off the switch under the steering wheel, and it stopped doing it.
Last month i decided to try and turn it to the on position, and 3 days later it did it , So i turned the switch back off. And hasnt done it again.
Anyhow good luck
kenEs350
ES - 5th Gen (2007-2012)
02-26-15 03:27 PM
