few 1jz swap aftermath questions...
Old 07-15-06, 11:48 PM
ippyness
ippyness's Avatar
Default few 1jz swap aftermath questions...
hey everyone, i just finished my 1jz swap using the 2jzge auto tranny, now i have a few problems.. one problem is that the car starts turning its self over when i hook up the battery, and another issue im having is the car doesnt accelerate very good and miss fires, i think the acceleration is because of the 2jzge auto tranny kick down cable, i have no idea how im supposed to hook it up, its to short to reach anything and i dont know if i even have ther ight bracket or right cable. any info would be greatly appreciated... thanks..
Old 07-16-06, 04:23 AM
5spdSC300
5spdSC300's Avatar
It sounds like your grounding the starter when you hook up the battery. I would check the starter wire. Im confused about your second problem. If the car is cranking itself over when you hook up the battery, how are you driving the car?
Old 07-16-06, 09:10 AM
ippyness
ippyness's Avatar
well, i hooked up a switch between the starter wire, sucks cause i have to pop the hood and start the car.. i cant think of anything that would make the car backfire when it starts to boost. and my car keeps popping the fuel injectors out.. really weird, when i get home today im going to rewire the knock sensors incase thats the problem.. hopefully... haha guess we'll see..
Old 07-16-06, 02:59 PM
5spdSC300
5spdSC300's Avatar
Also check for boost leaks if your car is backfiring when you hit boost.
Old 07-17-06, 05:04 AM
PJ
PJ's Avatar
I did the same thing.... i have a push button start now. Kinda a hassle, but i just need to figure out how to bypass the netural safety switch.
Old 07-17-06, 10:56 AM
Durrr
Durrr's Avatar
because people buy just the engine set
Old 07-17-06, 04:12 PM
happypanda
happypanda's Avatar
it feels good to know that im not the only one who has a push button start b/c of that starting issue when battery is plugged. goodluck to your project and hope you can figure out the problems and happy boosting=)
Old 07-17-06, 06:30 PM
95 Integra
95 Integra's Avatar
on that. Also are you running the correct MAF? Are you running an open or recirced BOV?
Old 07-17-06, 10:51 PM
Deceptik1
Deceptik1's Avatar
You mean MAP sensor.
Old 07-18-06, 12:32 AM
Bean
Bean's Avatar
This is true. And misfiring on a MAP sensor setup isnt going to be caused by boost leaks. What about the plugs? What are they gapped at? TPS calibrated correctly?
Old 07-18-06, 04:08 AM
ippyness
ippyness's Avatar
the reason im using my 2j tranny, is because i bought the engine from a friend who only had the motor, i had to get the turbos, DP, tranny, everything.. luckly i got everything for a good deal.. haha other wise i woulda just bought a front clip. anyway, my fuel injectors popped out..... and i figured out that im missing hte bar that holds those in.... spark plugs wernt tight ( he said he forgot to tighten them... guess i should checke though) that was the reason my car was missing so bad.. lol go figure.. anyway im working on making a custom fuel injector hold down right now but by chance can some one show me how the stock BOV vacuum hooks up, i cant find that info anywhere.. really sucks. but yeah thanks for everyones help, oh and where does the 5spd master cyl hook up in the engine bay? i dont see a place for one in my car, but im sure there is and im just over looking it, im hopefully doing my manual swap soon. but yeah thanks everyone for the help.
Old 07-18-06, 09:35 AM
kaosman
kaosman's Avatar
I had the same starting problem with my '95 SC300 5-speed after doing the swap. Here's what I did to fix the problem.
Find the 8-pin connector right next to the battery...you'll probably have to take the battery out. It will be mounted on the side of the black relay box. There will be two connectors here - the connector we want to splice in to, and another connector with 2 or 3 large wires. Leave that one alone.
On that 8-pin connector, find the black wire. This is the "signal" wire for the starter relay. What is happening is, for whatever reason, this wire is being supplied with 12 volts no matter if you're trying to start the car or not...and that's why the starter turns over the moment you put the battery on. Cut the black wire, leaving enough room on the CONNECTOR side to splice a wire in. Either crimp it or solder it - I'd recommend soldering - and run this wire through the firewall and down near the ECU.
Now you need to find the 1JZ "CF1" connector. It is one of the gray BODY connectors. A picture of it is here. You need to put a pin in position 8, this is the stock 5-speed starter relay activation pin. What I did was take a pin from my old 2JZ-GE harness, solder it onto my new starter wire, and push it in position 8 of the CF1 connector. Then my car started exactly as it did before the swap.
Old 07-18-06, 03:03 PM
5spdSC300
5spdSC300's Avatar
You are correct. Im just so use to troubleshooting turbo cars with mafs that the first thing i always look for is a boost leak .
ippyness: The master cylinder sits next to the brake booster in the engine bay.
Old 07-18-06, 04:06 PM
ippyness
ippyness's Avatar
i know where it should go.. just like on supras, but is the auto and 5spd brake booster diffrent sizes? i dont see any holes in the firewall or anything around my brake booster, anyway if any one has a picture or diagram for the stock BOV routing, and a picture of the master cyl that would be awesome thanks.
driftsc3
10-02-14 06:29 PM
504SC
08-20-14 09:50 AM
baconbomb
05-25-12 03:09 PM
OneJay
06-27-08 01:19 PM
ippyness
07-28-06 05:38 AM
Quick Reply: few 1jz swap aftermath questions...
