NA to NA-T Swap? Any Suggestions
Old 07-07-06, 07:30 PM
zinkie13
zinkie13's Avatar
Default NA to NA-T Swap? Any Suggestions
I've been a member of the board for only a couple of months now and haven't really had a chance to post much. I recently purchased a 1992 5 speed SC300. I also purchased a NA supra motor that had a turbonetics turbo kit installed on it. I'm looking for suggestions of other items I may need or suggestions as to how to make the swap go smoother. My current parts list follows:
Walbro Fuel Pump (installed)
Boost and EGT Guages (plan to install in guage cluster)
New 1997 supra engine mounts
New 35 mm wastegate
ACT Pressure plate (I have an extra one if anyone needs one)
Horsepower freaks 6 puck racing clutch
MAP ECU
18 X 8.5 20mm with 245 40 18 and 18 x 9.5 35 mm with 275 35 18
3.0 mm headgasket (installed)
Following is what was included with the turbonetics kit:
T04E-60 Turbonetics Turbo
Thermocoated Cast-Steel Turbo Manifold
Thermocoated 3" Mandrel-Bent Downpipe
Turbonetics Evolution 35mm Wastegate
Spearco W.A.V.E Front-Mount Intercooler
Silver Metallic Intercooler Piping
MF2 ERL 3D Map Injector Controller
440cc Lucas Fuel Injectors (2)
Turbonetics Raptor Blow Off Valve (BOV)
2 Bar Map Sensor
K&N Air Filter
Boost retard Controller
I am just looking for any help I can get. Thanks ahead of time!
Old 07-07-06, 08:12 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
moved to engine forum.
Old 07-09-06, 02:08 PM
zinkie13
zinkie13's Avatar
Anyone have any ideas? or does this sounds like a pretty good start?
Old 07-09-06, 02:15 PM
bens sc
bens sc's Avatar
actually its a great start, the kit is very complete as long as you have everything needed that comes with the kit. some of the pipe fitment is tight especially on the drivers side where you need to connect to the intercooler. next tight spot is on the pass side near the alternator where all the piping needs to go past the lower coolant hose. other than that a semi tight fit next to the distributor cap but very workable.
Old 07-09-06, 02:29 PM
zinkie13
zinkie13's Avatar
Hey thanks again! I've now had the car and the motor for almost 3 months and haven't done much with it. I'll be recieving the downpipe and extra injector controller this week. I believe those are the last two things I need for now.
Trider98
SC- 1st Gen (1992-2000)
12-02-14 12:53 PM
need2boost
SC400 / 300 Classifieds
30
05-08-14 09:42 AM
JenovaI
07-04-13 01:50 AM
ScReaper
CL of Southern California
03-27-11 11:31 AM
SC400TT
01-14-04 08:26 PM
Quick Reply: NA to NA-T Swap? Any Suggestions
