How to remove torque converter clutch?
Old 06-25-06, 09:12 PM
trangk
trangk's Avatar
Question How to remove torque converter clutch?
Okay I feel stupid, but gotta ask in order to know the answer
Is there a trick to removing the 6 bolts that hold the torque converter clutch in the transmission? Need to remove transmission from the engine and these 6 bolts don't want to budge at all. Any tricks or hints? Or do I just need to hit it with a ton of PB Blaster and use a really big breaker bar? No compressor tools unfortunately
Here is what I'm talking about:
Old 06-26-06, 03:16 PM
2JZ_SC
2JZ_SC's Avatar
Use a screwdriver or somthing to hold the torqueconverter is place while you pull on the wrench. you can slide it into the holes in the flex-plate and turn it untill it stops aginst the dust cover.
marvin5881
03-23-19 01:06 AM
kez
08-03-10 07:15 PM
wagomaniac
SC- 1st Gen (1992-2000)
08-02-10 10:06 AM
2jzNoShiz
03-21-10 12:36 AM
SC300_704
14
01-02-08 08:36 AM
Quick Reply: How to remove torque converter clutch?
