1jz sc starts up but dies when throttle is pushed
Old 03-18-06, 01:14 PM
SoarerJzz3
SoarerJzz3's Avatar
Default 1jz sc starts up but dies when throttle is pushed
My car was running fine yesterday until I got home. I attempt to push on the throttle and notice it cut out (thinking maybe it was fuel cut). So I drove the car up the hill and seems to get worse, the more I push on the throttle it would just cut out.
As I was turning into my apartments the car dies. It took a couple of cranks to get it running again and it just sputtered the rest of the way, and then died when I parked it. WTF. I jumped in it today and still took a couple of cranks to start up and barely put my foot on the gas it died. My guess is maybe the fuel pump has gone out or the fuel filter is clogged up. Can anyone help? Thanks
Old 03-18-06, 03:35 PM
1sxyrxy
1sxyrxy's Avatar
do a fuel pressure test
Old 03-18-06, 03:37 PM
indypwr
indypwr's Avatar
did you upgrade your fuel pump? this happens to me once in a while and i noticed my walbro pump sometimes does not come "on". all i did was to shut if off for a few seconds and started it up again. i think it's a bad connection of my pump for the power source.
Old 03-18-06, 04:32 PM
SoarerJzz3
SoarerJzz3's Avatar
No, i'm still running the stock pump. Figured it's enough since it's stock.
Old 03-18-06, 05:03 PM
turbodude
turbodude's Avatar
pump is dead... almost gauranteed.
Old 03-18-06, 07:45 PM
VJ RC51
VJ RC51's Avatar
stock pump is plenty on stock boost... did u bypass the fuel computer? if not thats your answer.
Old 03-18-06, 07:48 PM
SoarerJzz3
SoarerJzz3's Avatar
How would I go about bypassing the fuel comp.
Old 03-19-06, 08:44 AM
VJ RC51
VJ RC51's Avatar
Its behind the drivers side passenger window. Take out the seat (3 bolts) and careuflly undo the panel. Hook the two big power wires together. Theres posts all over that get more detailed.
Old 03-19-06, 01:05 PM
GRSC400
GRSC400's Avatar
check your spark plugs they might be going bad with all that starting up, and check your fuel pressure before u star changing parts
Old 03-19-06, 01:12 PM
B.Diddy
Lexotic Concepts
B.Diddy's Avatar
I would check my fuel pressure before assuming anything else. It could be an electrical gremlin with the TPS or MAF voltages. Dont assume anything
Old 03-19-06, 01:17 PM
VJ RC51
VJ RC51's Avatar
you have to bypass the fuel computer on a 1JZGTE or 2JZGTE swapped SC300/400.
Old 03-19-06, 03:08 PM
ki_soarer
ki_soarer's Avatar
lets start with the basics.... make sure your not on empty, and make sure its not just bad gas.
Old 03-19-06, 04:07 PM
SoarerJzz3
SoarerJzz3's Avatar
Well I had a Soarer fuel pump when I bought my swap, tried it out and it started up, ran fine. Thanks for all your input, hope this helps someone in the future.
jzs14
05-12-13 01:03 PM
SC300_704
11-12-12 06:51 PM
blitz93gs
02-16-12 02:28 PM
jefferino
07-21-08 01:52 PM
smooche
07-14-05 06:26 PM
Quick Reply: 1jz sc starts up but dies when throttle is pushed
