BOV choices??
Old 02-16-06, 06:58 PM
laxdude362
laxdude362's Avatar
Default BOV choices??
So I am closing the gap on my turbo parts. I am looking to buy a BOV pretty soon. For those that have one, which do you have and do you like it?? What all do you guys reccommend? I was thinking something like Greddy Type S, Greddy Type RS, HKS SSQV.
Old 02-16-06, 07:28 PM
ATL-SC
ATL-SC's Avatar
get a first gen dsm bov not only is it cheap but it is unbreakable.
and all you need to raise the boost is a manual boost controller
plus (and this is the worst part) it is one of the best sounding.
but from the list you made i would say you are not on a budget build and with that said the dsm bov just wont have the bling factor your lookin for
Old 02-16-06, 08:11 PM
laxdude362
laxdude362's Avatar
How much do they run for and where could I get one? I have the money for the ones I listed.
Old 02-16-06, 08:14 PM
SinisterSC
SinisterSC's Avatar
Tial 50mm. You'll be happy with it. I've seen 'em on damn near everything. Great. My perfered on the market.
Old 02-16-06, 08:20 PM
chitwnsazn
chitwnsazn's Avatar
what is your budget?
Old 02-16-06, 08:28 PM
laxdude362
laxdude362's Avatar
I don't want to spend more than around $200.
Old 02-16-06, 09:49 PM
SCoupe
SCoupe's Avatar
Default Hks Ssqv
HKS SSQV is one of the most widely used BOV's on the 2jz-gte, bar none. You'll see this vividly on the SupraForums. Probably outnumbering all others combined, bomb-proof reliability, sound effects. Good luck on your project, you're off to a good start. Take a hard look at upgrading the radiator, all aluminum Koyo Radiator for the Supra fit, also don't forget the TT Brakes, suspension and sways, you'll want them when you find out just how freaking fast your car will be.
Old 02-16-06, 10:08 PM
indelible
indelible's Avatar
my vote goes for the hks ssqv, hands down.
Old 02-16-06, 10:28 PM
indypwr
indypwr's Avatar
im running the hks type II racing bov and lovin' it.........
Old 02-17-06, 12:21 AM
Exive
Exive's Avatar
Does the BOV has to do anything with the cars power? What I was told that it doesnt actually gve any hp...am I wrong?
Old 02-17-06, 04:08 AM
chitwnsazn
chitwnsazn's Avatar
well if you want a whistle sound (high pitched noise) then go with the ssqv or greddy type s. There's a pretty good thread on supraforums with sound clips that helped me decide what bov to go with (remember, the sound also depends on the amount of boost you're running). As for the HKS racing, don't you have to let that be recirculated back (I have the first model of the hks racing bypass valve I'll give you for $75 )? I agree that tial bov sound the best but at a cost.
Old 02-17-06, 07:45 AM
vipsoarer
vipsoarer's Avatar
if your going to turbo your lexus dont get a dsm bov. they leak past 14 psi and need to have the head crushed to handle more boost, plus why spend all the money on a nice turbo setup to run a dinky *** worthless bov. I had a HKS ssqv and i loved it. never had a leak and adjusting it was easy.
exive: no a bov does not give power. it releases the trapped air in between the turbo and throttle plate when the throttle plate is closed. this is so that you dont get compressor surge (trapped air that forces the turbo to spool down and while exhaust gases are still going to the turbine side, thus torquing the shaft and eventually breaking the turbo.
Old 02-20-06, 01:15 AM
mrshabo
mrshabo's Avatar
indypwr. how much hp your making/boost? i heard those bovs require a lot of boost to release the air properly.
Old 02-20-06, 07:25 AM
vipsoarer
vipsoarer's Avatar
mrshabo they suggest having over 18psi for the bov's but as with any turbo setup you will shift below that pressure. the hks racing will do for any turbo setup but will be most efficient for one running over 18psi
Old 02-20-06, 08:37 AM
ATL-SC
ATL-SC's Avatar
hey if you are on a budget and you are runing low boost(anywhere from 7 to 10) the dsm is a great choise. but if you have spent a good amount on your kit, i would invest a little more too. having said that i must also say as great as the tial is i definatly think its overkill.
so go greddy
Quick Reply: BOV choices??
