Fastest 1/4 mile time - SC400 only
#196
Quick update,
Tomorrow is a 1/4 mile track day at my local track. I don't know how many runs I'll be able to get, I'm pretty sure it will be crowded since they are having a big PTRA event / race on Saturday.
I haven't really had any good short times on the Hoosiers and my rear street tires were about worn out anyway, so I decided to try a pair of Nitto DR's. 275 40 17's, probably should have went with the 315 35 17 but oh well.
Wish me luck!
Wish me luck!
#198
Ran a 12.62 last night at 111.xx with a 1.936 60ft. New best.
This is on the nitto's. Still don't know why I can't manage some better 60's......
It kind of sucked, I only got three runs.
KC
Oh, and my car weighs 3728 with me in it + a 1/4 tank of gas and a laptop, not much else. I weigh about 190-200lbs so I guess that's pretty good for a 95, the heaviest year if I'm not mistaken.
KC
#199
Hey guys, found this video on youtube and thought you'd be interested. I have now idea who the filmer is but that's my car at the Zmax dragway a few weeks back. And yes, that is a Vette I made look slow.
http://www.youtube.com/watch?v=iFHQH-Aruj0
I haven't beaten my 12.62 time yet but have gotten close a few times despite the much higher temps lately.
The last few times at the track I've had tuning issues. Running water meth and no intercooler. The most recent time, I ran a few 12.8's - 12.9's with my AFR pegged below 10:1. I've got that issue fixed but haven't been back yet.
Also been having another problem, the brakes won't hold the car when stalling, wants to creep forward over 2200 rpm.
KC
KC
#200
SC400 99-2000 300hp!
On an sc400 99-2000 has 300hp correct? Can any one guess what kind of 1/4 numbers will I be running with 100shots of nitrous? The car will be bone stock with the purple bottle, forgot the name, Lol..
#201
KC
KC
#202
Ya, it's pretty funny. I like the "what's goin on here, whaats goinnnn on!?".
FYI guys, I ran a 7.874 1/8 mile on 9-11. Went to a 1/4 track on 9-16 and could only manage a best 1/8 of 8.058 which resulted in a 12.516 1/4 mile time. Was humid as hell in Darlington (1/4).
Planning to go back this Wednesday, forecast is cool, clear and dry. Hopefully I will run some 12.0's!
And, from now on, I will update my times here - https://www.clublexus.com/forums/per...1-8-times.html
Subscribe to the thread if interested! Hope to get some videos soon, in car if nothing else.
KC
KC
#204
I did post just not hear. Seems as though there is no interest in this thread so I started a new one for my times.
But yes, went 12.047.
I hope to break the 12 second barrier one way or the other, I think I should be able to run 11.8's to 11.9's. Just a matter of being on the right track with the right weather with the right launch. If not, I might look into a small nos shot.
Gonna do it or blow it up trying. LOL. Hopefully will be running this Saturday coming up.
KC
KC
#206
KC
KC
#209
Originally Posted by b1ackhawk
really quick man. Do you have stock internals?
Originally Posted by stevechumo
You may watch out for that NOS. I think your stock 1UZ is pushing its limit already. But congrats!!!
Originally Posted by the3rd
KC I know this has probably been asked a million times but what kind of power are you making ? And what's your setup like performance wise.
I've been working on a complete mod list. Probably missing something.
Engine / Induction / Fuel
Vortech V-9 counter-clockwise rotation supercharger (about 12psi)
Using "the fish" bracket for supercharger
Custom serpentine belt setup with a custom manual tensioner
Maft-Pro piggyback - stock ECU - running MAFless
Water / meth injection
EGR delete
Modified PCV
Bell Engineering FMU
Walboro HP pump
Supra (MK3) 315cc injectors
Denso IK27 plugs
Megan engine and trans mounts
AEM wideband
Cooling
95ish Camry electric fans
Hayden fan controller
Deleted hydro fans, using LS400 fan bracket
Mostly water wetter and water, some coolant
Mr. Gasket 160 thermostat
Coolant bypass of EGR, IAC valve and throttle body
Drivetrain
Stock transmission built with IPT valve body, IPT 2nd gear sprag and IPT rebuild kit.
Disconnected no4 solenoid
3000ish stall Dragon convertor
Rather large fluid cooler
Torsen LSD center installed into stock rear
Solid diff earmounts
Suprastick trans controller
Exhaust
IMF (EKT) headers
2.5 inch custom dual mandrel
Magnaflow dual in/out tru-x center muffler
Dual Magnaflows in the rear
Suspension / Brakes
Prothane front CA bushings
Prothane rear CA bushings
Prothane sway bar bushings
TME steering rack bushings
MK4 front strut tops
Tokico rear strut tops
Tokico front / rear Illumina adjustable struts
Megan traction rods
EBC "redstuff" pads front and rear
New (aftermarket OEM type) rotors front and rear
SS brake lines
Weight reduction
Removed spare and tools
Racing seats (cheapies)
ABS / TRAC delete
Originally Posted by Ali SC3
those are some good times.
KC
