oil pump (2jzge and 2jzgte = same?)
i'm currently deciding whether or not if its worth piecing together a 2jzgte...
and need to know... first of all
where is the oil pump on a 2jzgte... and can the one from a 2jzge work?
and I'd search... but supraforums is down
gte & na-t
Only the OBD2 2jz na have the crank sensor hole on the Oil Pump and yes the oil pumps don't have the same part numbers but it should work.
If you need one just buy the tt oil should be about the same price maybe even cheaper, like the water pump the TT water pump is cheaper than the na..
The crank sensors are the same part numbers.
