Changing clutch
Old 12-14-05, 05:10 PM
J J
J J's Avatar
Default Changing clutch
Is there a write up online for this? Is it fairly straight forward? I saw some pictures on a clutch change on a 6 speed supra where they had to unbolt the pressureplate before pulling the tranny, is that the case on the 5 speed too?
Old 12-14-05, 05:19 PM
/Aerostar\
/Aerostar\'s Avatar
Nah u dont have to unbolt the pressure plate, and the whole process is actually pretty straightforward. Do a search and youll find how to do it, I know I did atleast one. Also, get a repair manual
Old 12-14-05, 05:31 PM
95 Integra
95 Integra's Avatar
No, on the 5 spd you dont unbolt it first. To be honest the way the 6 spd does it, it makes it much easier to line up the tranny/clutch but with the 5 spd you'll struggle a bit to get it lined up right.
Old 12-14-05, 08:34 PM
Arizona
Arizona's Avatar
J J I applaud you on trying this your self. I love to see people try working on their cars. Changing a clutch on these cars is pretty stright forward. Honestly Just get under your car and look at it. Getting a Repair manual is a good idea to.
Old 12-15-05, 12:22 PM
SPORTcoupe
SPORTcoupe's Avatar
Tip: Do replace the TO bearing even if your current one doesn't squeak, and make sure you put it in the same way it came out.
If you have to, take a picture of the fork/TO bearing assembly before taking it apart. It'll save you having to do the job again like I did. (It wasn't I who put the TO in backwards, it was my friend...but it was me who had to re-do the whole job)
ALSO: A few extra extensions and a swivel joint will make your job 10X easier, trust me.
~Alan
Old 12-15-05, 03:56 PM
/Aerostar\
/Aerostar\'s Avatar
oooh oooh TIP: To get the top few bellhousing bolts EASILY, unbolt the tranny support so it droops down, then use 3 or 4 FEET of extensions to reach the bolts. Those swivel joints can be a ***** to use, so I found this way to be a lot easier (I did this job 5 times)
Old 12-16-05, 03:12 AM
mrshabo
mrshabo's Avatar
Great tip, thanks aerostar.
Devor
SC- 1st Gen (1992-2000)
01-21-12 07:05 AM
LMAOMAO
02-06-09 03:50 AM
LCSC
03-28-08 04:47 AM
scredlex
04-25-06 10:56 AM
Quick Reply: Changing clutch
