TT auto tranny swap
Old 11-11-05, 09:46 AM
soarer479
soarer479's Avatar
Default TT auto tranny swap
about to finally nut up and swap everything in. so just to make sure i have everything id like someone who has done the swap to go over this with me once more...... what i have right now tt auto tranny (boostlogic built) tt auto flex plate, built tt torque converter (lextreme is the shizznit), and of course the sc400 drive shaft. is there anything else?? i know there is some wiring required so also if any one has the diagram or can tell me what needs to go with what. also taking a look at the tranny the guy didnt include any type of electronics besides the plug ins directly connected to the transmission itself. thanks for any one that can help.
-hank
Old 11-11-05, 11:20 AM
gadgetSC
gadgetSC's Avatar
TT Bellhousing, if you forgot to list. TC bolts(6) for the TT(much bigger than stock).
gadgetSC-t
Old 11-11-05, 02:54 PM
soarer479
soarer479's Avatar
yah ive got the bell housing but not the tc bolts. the part i really need help with is the wiring.
Old 11-11-05, 04:26 PM
gadgetSC
gadgetSC's Avatar
Are you using an AEM?
gadgetSC-t
Old 11-13-05, 07:19 PM
soarer479
soarer479's Avatar
yup im on ems what i really need help on is the wiring
Old 11-13-05, 11:35 PM
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
Eventually you will have a problem with SC400 driveshaft. Get a custom one if you can. The rubber couplers will get ripped apart and you might find yourself stranded.
Chris
Old 11-14-05, 05:51 AM
gadgetSC
gadgetSC's Avatar
Same here. Was fine till went with wider tires.
gadgetSC-t
Old 11-14-05, 06:27 AM
aliga
Former Sponsor
aliga's Avatar
gadget, are u still running the sc4 ds with the machined couplers?
Old 11-14-05, 10:08 AM
DIrEctQL
DIrEctQL's Avatar
I think I will just get a custom driveshaft. Looks like the SC400 driveshaft won't be able to push too much power anyway.
Chris
Old 11-14-05, 11:25 AM
kietlander
kietlander's Avatar
wait is there a difference in the TT tranny and the stock rear diff? wouldnt that make a big difference?
Old 11-14-05, 05:40 PM
DIrEctQL
DIrEctQL's Avatar
Yes, one is a transmission and the other is a diff. Repeat that question in a form that makes sense.
Chris
Old 11-14-05, 10:15 PM
gadgetSC
gadgetSC's Avatar
Hey Gazi. I swapped out the SC400 ds for the one-piece as sonn as I found the damaged couplers. The rubber couplers were fine until I put on some 285's in the rear
gadgetSC-t
Old 11-14-05, 11:38 PM
TurboB6
TurboB6's Avatar
Hey that stuff looks familiar
Shoot me a pm sometime George. Hope all is going well.
Old 11-15-05, 07:24 AM
soarer479
soarer479's Avatar
so i guess after hearing all that i will just wait and get a custom 1 piece drive shaft. on another note how well does the rest of our drive train hold up axles etc im finally about to get a tune on the car with the ems and the new fuel system. it has been a long and tempting break in period but im finally about to put the motor i built to good use. i just wanna make sure im not going to be killing my drive train when i do
Kylestt
01-16-09 02:31 PM
tuninghaus
11-08-07 12:21 AM
AIsc400
09-21-07 05:55 AM
FortuneLS
29
08-25-06 03:47 PM
soarer NAT
11-19-03 10:43 AM
Quick Reply: TT auto tranny swap
