i need traction!!!!1
Old 11-03-05, 07:31 AM
VJ RC51
VJ RC51's Avatar
Default i need traction!!!!1
14.4 @ 100 with a 2.4x 60ft.
Bone stock 1JZGTE on stock psi, stock NA exhaust with no mufflers, just resonators, 255 series bald pilots and an OPEN diff. I didnt stop spinning and actually take off til middle of 2nd gear launching off 1100rpm. I hate bithlo, i get better traction on public roads!
Better watch out Chino!! 13.5 @ 104 is plenty do-able on my stock motor at stock psi with no electronics, gimme a few weeks to work out the suspension
Old 11-03-05, 10:29 AM
VJ RC51
VJ RC51's Avatar
275 40 17 DR = next mod
or slicks
Old 11-03-05, 10:40 AM
Aristo300
Aristo300's Avatar
Post a timeslip or be shot.
Old 11-03-05, 10:46 AM
quikturbo
quikturbo's Avatar
Excellent!
Slicks may be overkill at this point, especially with the open rear.
Keep up the good work
Chris
Old 11-03-05, 10:48 AM
Aristo300
Aristo300's Avatar
If you can get a 2.1-2.2 60ft you will go 13.9-14.0 easily.........
Old 11-03-05, 11:28 AM
VJ RC51
VJ RC51's Avatar
My goal is to beat chino's time of 13.5... with no engine mods
275/40/17 drag radials will be in the mail within a week or 2 along with some suspension changes. I feel with a good launch under boost and a nice 1.8 60ft, open DP i can be low 13s!
Old 11-03-05, 12:09 PM
codetoad
codetoad's Avatar
are you auto? if not what clutch do you have?
Old 11-03-05, 12:14 PM
VJ RC51
VJ RC51's Avatar
I'm auto without the correct tranny ECU, so i have to manual shift it. Kinda gets tricky 1-2, u gotta click the shifter up almost 2k rpms before it actually shifts, i still ended up having to let off full throttle cause i hit the rev limiter
Old 11-03-05, 12:22 PM
codetoad
codetoad's Avatar
oh ok. Yeah, sounds like you need some traction
Im going to have to watch it when I get on the gas, im gonna have my stock wheel/tires on there.
Old 11-03-05, 12:23 PM
VJ RC51
VJ RC51's Avatar
Depends on air temp, but if its anywhere from 50-65 degrees, on the road there is NO traction 1-2nd
Old 11-03-05, 12:57 PM
AME_VIP
AME_VIP's Avatar
Funny I'm having to shift 1-2 on my SC400 auto with spray or else it will hit the limiter. I also have to shifter 1500 or so before redline and I usually end up letting off a little
good luck on your goal of low 13's. That is also my goal but I may need DR's as well.
Old 11-03-05, 01:58 PM
VJ RC51
VJ RC51's Avatar
Especially with my open diff, i think my only route to go is going to be full slicks. I also have to get my tranny shifting in order, letting off and hitting the limiter is costing me a few mph. Low 13s with no electronics and stock psi should be easily attainable, this motor has great mph. My goal of the night no matter the ET was 100mph, and it hit it with driver errors (shifting, wheel spin).
As the air cools and i add on some spark and fuel management, it might seem kinda far fetched, but since this motor likes to go... i wanna try to get 12's within the next few months on stock 9psi.
Ok ok flame me.... but watch out in the next month or 2!!
Old 11-03-05, 03:24 PM
ki_soarer
ki_soarer's Avatar
i saw the timeslip... its true. i dont think you will get into low 13s with that open diff. it just seems a bit crazy to me. why spend the money on slicks when it would be better spent on an LSD? and another note..... im sure the next time chino is at the track, he will se 12s.... but thats just my opinion.
Old 11-03-05, 04:05 PM
VJ RC51
VJ RC51's Avatar
yeah he might run 12s, but he's fully modded cept cams and big turbo!!
My open diff will slow me down some, but some normal size slicks will help! I just need to source a 15x10in rim that fits the body! I didnt build this car to street race, its all for the track. I don't care what it does on public roads. My goal is to hit 12s on stock PSI, but with other electronics. I wanna get 13.5 with no add-ons. A 1.80 60ft should make that happen. Ive seen plenty open diff 3600lb cars get 1.80.
Shane last night was running 11.7x with just his T76 and open downpipe, bone stock everything else (cept drag radials). He's my hero lol
Old 11-03-05, 05:19 PM
DETUNED
DETUNED's Avatar
i'm sure you can get low 13's on your open diff. I went 13.4 in my stock sr and an open diff with a 2.4 60
Quick Reply: i need traction!!!!1
