electrical nightmare
Old 08-22-05, 08:34 AM
TWISTED II
TWISTED II's Avatar
Default electrical nightmare
well, after having the car torn apart numerous times, doing all sorts of things to it, there are some weird electrical problems.
1) turn signals and hazards don't work.
2) climate control lights turn off when headlights are on, and on when headlights are off.
if anyone has any ideas or troubleshooting options, it would be a huge help. and yes i've checked the fuses and everything is plugged in, lol.
Old 08-24-05, 02:34 PM
TWISTED II
TWISTED II's Avatar
well the climate control lights have been fixed, but the turn signals still don't work at all. nothing. no clicking or anything.
Old 08-24-05, 04:09 PM
soarer479
soarer479's Avatar
make sure your hazard button is plugged in, in the back this will cause the turn signals not to work as well as hazards
Old 08-24-05, 04:20 PM
TWISTED II
TWISTED II's Avatar
what do you mean in the back? the hazard button is plugged in the middle dash area if thats what you mean. is there another plug somewhere that might have come unplugged?
Old 08-24-05, 06:59 PM
j three
j three's Avatar
Lightbulb
A friend of mine has a project car and had a similar problem, and what we did was take the blinker wand apart and make sure the contacts are cleaned very good. Then make sure the contacts are touching. I dont know how the sc is set up but you might as well give it a try. Btw we had to pull the steering wheel to take apart the steering column pannels. Good hunting
Old 08-24-05, 07:14 PM
setwire
setwire's Avatar
Default No turn signals
Check the easy obvious things 1st.
Blinker relay
loose connections at back of your hazards.
Doubt very much if it is a bad contact in your steering column.
Sounds to me like burned out blinker relay.
Rob
Old 08-25-05, 03:05 PM
TWISTED II
TWISTED II's Avatar
Blinker relay
Rob
hazard is good. i don't have my center area in, so, i just have the hazard switch hanging there, and i can push it and knows its in there good. now, the blinker relay. thats a good place to start. where is that located?
Old 08-27-05, 02:49 PM
TWISTED II
TWISTED II's Avatar
anybody know where the blinker realy is? lol
Old 08-28-05, 12:07 AM
setwire
setwire's Avatar
Default Flasher Unit
Flasher is located in Relay Block #4.
Which is located in the front section of your fuse box in the drivers left foot area.
When you look at the relays in the section nearest the firewall it is the top left or the only relay on the left side .
While you are down there check fuse # 9 which is your turn signal fuse --20 Amps.
Rob
Old 08-28-05, 11:01 AM
TWISTED II
TWISTED II's Avatar
thanx man. luckily i got it fixed. i feel like a total schmuck, but heres what was wrong. apparently, there are more than one plug that clips into the hazard button, haha. so yeah, since everything is out of the front dash, i just started matching plugs, and left it in the first one that fit. well, when i went to reassemble the front dash yesterday, i realized that clip would never reach to where the hazard button had to mount, so, once the wires were being lead to where they needed to be, i saw the correct plug for the hazard button and it was all good. whew, weight off my shoulders. thanx to all that tried helping though.
obi-1
08-04-11 06:28 PM
jewelberry
05-24-11 10:17 PM
ls400808
04-07-09 12:42 AM
Quick Reply: electrical nightmare
