5sp to 6sp swap questions
It looks like I'm doing a 5 speed to 6 speed swap and after reading all I can find I still have a couple of questions.
I will also be putting in a 6-speed tt rear end and RPS Max street clutch. I think I understand the issues with the shifter and the slave cylinder. The car will be used for road racing with 350-450 rwhp.
What is the best route regarding the drive shaft --- modify a SC300? modify a TT ? complete custom?
Do you think it is necessary to upgrade the drive belt tensioner?
Do you need to change the right rear axle or only the left?
Any other words of wisdom from those who have BTDT?
Thanks
Jon
Thanks
Jon
Supposedly only one of the TT half-shafts is needed (left side?); however, I've heard that the TT half-shafts are beefier than the SC ones, so you might as well swap in both sides. I have not seen a side by side comparison, so am not sure. Besides a drive shaft, you will also need a flywheel, clutch, and pressure plate...
We have never had much luck with a one piece D/S, seen alot of vibration problems. My SC has a extended 6 spd drive shaft. SW has one too. The car that ran 10.1 @ 144. I think that speaks for the strength of a 2 piece. Jon, I can have one built for you. Just give Zohair or Kean a call.
Thanks all for the info.
Did anybody do the belt tensioner upgrade?
Jon
PS Chris congratulations on the 1,000 hp supra write up. I can just show people the mag and say the same guy that did 3 of the 4 built my car
Jon
I don't know about for cheap.
The cheap ones all seem to need a rebuild which would probably add $2k if you can't do it yourself.
Ryan Woon (WOTM) has one around $3500 (after he has it rebuilt) and Sherbaz (search supra forums) has a brand new one he says has never been driven or raced which you can get for less than $4,000.
