Extra Heat with A/C
Extra Heat with A/C
Ok I was wondering if any you guys with a 2jz-gte swap had your temp gauge start to slowly go up after having the A/C on through rush hour traffic on a hot summer day (Florida - 100+ F). I have flex-dual-lite electric fans. And the temp gauge doesn't go up hardly at all when the A/C is off even when I romp on it. I am thinking about going with the electric water pump by Meziere eventually, and wanted to know if I am the only one experiencing this, and will the upgrade to the Meziere water pump help or not. Just want to hear any input. Oh and is there anything I can do to run the car a little cooler in the mean time. Talk to you guys later.
-Adriel
-Adriel
I already have the TRD Thermostat and water wetter but I just found out that one of my electric fans was cutting in and out cause the relay connection was intermiten. Most likely I will wire up a new relay. The heat under that hood is rediculous and the relays are becoming waurped. I need to find a location or a way to shield certian electronics from the heat, until I go single with ceramic coat. But thanks for the reply. I catch you all later.
-Adriel
-Adriel
ChronoJ1
Performance & Maintenance
16
10-28-05 09:10 AM
