need help with high presure hose
Old 07-19-05, 12:32 AM
antn
antn's Avatar
Default need help with high presure hose
my ps lfuid is leaking from the high pressure hose. i found out that there is a litte slit the causes the leak. the slit is found on the rubber hose and im tryin to take off that section so i can take it to this place to get it repaired but the bolt in the middle between the hoses in there really tight and it wont budge and im afraid that i will strip the bolt. i got the other end out and and i need help on taking the middle bolt out. any advice? thanks
Old 07-19-05, 12:40 AM
awj
Bluegr*** Performance
awj's Avatar
Take the whole thing off. Take it to the shop. Let them deal with it. Either way, you need to drop the whole thing in order the get torque on it in a vise or with a couple wrenches. Otherwise, you will wind up breaking the plastic clips/screws where the loop secures to the pan there.
Old 07-19-05, 12:48 AM
antn
antn's Avatar
kool, thanks for the reply. do you have any advice taking out the other end. i think the bolt on the other end is 20 or 22mm and the space to to fit a wrench and loosen the bolt is really tight to move the wrench. thanks
Old 07-19-05, 02:44 PM
awj
awj's Avatar
i use a deep well socket and 3/8 drive. it's tight.
gtstcactus
21
04-20-15 05:28 AM
ISFFUN
06-03-13 06:25 PM
lotusing
12-19-11 06:48 PM
JDMCelsior
12-06-06 08:05 AM
siniquezu
Wheels, Tires & Brakes Forum
10-29-04 12:42 AM
Quick Reply: need help with high presure hose
