sc turbo exhaust the cheap way
so I bought this on ebay for $165 shipped. its for a 350z from dual 2.5" to single 3" ss mid section.
I'm going to use it backwards. the 3" 2 bolt flange is the same as the 2jz 3" down pipe I have.
minor adjustments and adding a bit of more piping to the cans I have is all thats needed for the otherend.
Looks good. I think someone else was also talking about using the y-pipe from the 350z but never got a chance to see the results. Be sure to post pics when you get it on
y pipe
3"
Originally Posted by reamemiya
why are you going to make 34034589hp? hahaa jk
that's a real good price and quite the clever idea. by the looks of it looks like it might take a little work though. best of luck to you.
The only thing I see Ill have to do is add some piping and maybe turn the eands a bit
exhaust size
Originally Posted by Texas2jz
Why do you think dual 3inch is overkill? On turbo cars when it comes to exhuast, the bigger the better. I thought this was common knowledge by now.
Originally Posted by 2.5tsoarer
do you really think dual 3" is needed ? if you think so then all the supras would have 6" dia. piping
there are TONS of supras running around with 4" exhausts and still plenty that have the rare 5" exhaust...
course they make a lot of power
4" exhaust is pretty much common in the 600+hp range but plenty of BPU Supras run 4" catbacks
Single straight exhuast have been tested to flow better and make more hp.
I should have mentioned the dual thing before sorry.
Gregg
ALLWiTE2JZ
Performance & Maintenance
02-29-12 10:11 AM
