Oem Ram Air, cost $0
Old 05-30-05, 10:37 AM
leostunts
leostunts's Avatar
Default Oem Ram Air, cost $0
Economy ram air.
Cutt tabs at end and flip over.
Parts needed- 2 small wood screws and wire cutters to cutt tabs.
with 1 pic 2 more will follow.
I guess its 1 pic per post?
Attached Thumbnails Oem Ram Air, cost alt=
Old 05-30-05, 10:40 AM
leostunts
leostunts's Avatar
pic 2 and pic 3 is next.
Old 05-30-05, 10:42 AM
leostunts
leostunts's Avatar
pic 3 cutt both tabs at end.
Old 05-30-05, 11:57 AM
JspecSC3
JspecSC3's Avatar
What is that on pics 1,2 and...3?
Old 05-30-05, 11:59 AM
got_trd
got_trd's Avatar
looks like the air duct that goes under the passenger headlight... I dont see how its ram air though?
edit- n/m... he moved the air duct down to one of the openings on the bumper.. i see..
Old 05-30-05, 12:43 PM
MR-2 Turbo
MR-2 Turbo's Avatar
So did you feel any power gains?
Old 05-30-05, 07:46 PM
SupraCoup3
SupraCoup3's Avatar
a very cool idea, it'd be interesting to see how it compares against the BFI...
The BFI, done completely correct uses the entire lower opening of the front bumper as a ram-air system
Then again, some people, like lazy old me, don't do the complete BFI
Old 05-30-05, 08:07 PM
KrazeMatik
KrazeMatik's Avatar
this look intresting does this gain more power? try to give us better set up and pics!
Old 05-30-05, 10:01 PM
SC300Es
SC300Es's Avatar
better quality pictures please.
Old 05-30-05, 11:07 PM
ummagawd
ummagawd's Avatar
looks interesting....
what is it?
hehe just kidding..... but yea... possible to get better quality pics? I'm interested
Old 06-01-05, 03:20 PM
leostunts
leostunts's Avatar
Feels like it pulls better mid and top end.
You could add a connecting funnel of some sort to the front of the bumper.
And finish it completely. I'll probably do that, something from home depot should work.
First pic- how it sits in car
2nd pic-looking thru front bumper grill after install.
3rd pic-there are 2 tabs at the end, you'll need to remove to fit in there properly.
After you flip it over and shove this piece back into the air box, screw in 2 scews on top since you have to remove tabs that use to hold this piece in place.
Sorry for the crappy cell phone pics.
Warning- one of the bolts you need to remove is a ***** to reach, best tool for this is a 10mm ratchet rench or remove headlight and it'll be alot easier to get to.
Try it can't hurt anything.
Old 06-01-05, 06:04 PM
SC400TT
SC400TT's Avatar
Yes it can...If you go through a bad puddle or get splashed by another in that area, you could end up with water in your engine and the dreaded hydro lock. If you're going to do that, you need a bypass of some sort.
Ryan
Old 06-01-05, 06:22 PM
Koma
Koma's Avatar
Ryan
I've heard bypass valves aren't really that good either. I bought a bypass valve a while back and never got to install it because I never got my CIA for my celica. It's a 3 incher. I'm probably never going to use the thing. It looks pretty though.
Old 06-02-05, 09:44 AM
ummagawd
ummagawd's Avatar
bypass valves (at least the ones i've seen) are only good if the intake filter is completely submerged in water.
otherwise... droplets of water will still go to the engine (and if enough) will give you hydrolock.
Old 06-02-05, 11:50 AM
leostunts
leostunts's Avatar
It takes a good amount of water to travel up the funnel thru the filter, which it would have to be saturated first ,and then suck up thru the afm and up the large hose to the throttle body.
I use to drive a turbo charged car at 20psi , with the screen mesh air filter
in front of the front tire in the rain.
And yes I sucked up some water engine would stumble, of course I would let off. It would clear up and I would countinue driving and try not getting into boost and it would be fine (mind you this happen about 5-6 times) car still ran strong after this happened.
And this was with extreme forced induction(Turbo). N/A motors don't suck as much ,as forced induction motor.
If your afraid of hydolock,don't try it.
I live in Cali, and it hardly ever rains here.
Quick Reply: Oem Ram Air, cost $0
