Post your 1jz swap issues
#46
Originally Posted by 1JZsoarer
man, someone needs to change my damn screenname. THis was when I was 1j dreaming, now it's a diff game
#49
Matt, I've been working retarded hours so everytime I get home I lay in bed and pass out. I'll be on soon enough though.
#52
Originally Posted by mteele
Yeah, he is pissed because I have more then him and I've been around here on CL a lot less time As long as I beet him to 1,000 I'll be happy.
#53
Swapped 1JZ Soarer engine into 92 SC300.
Water temp works perfect
Tach works perfect
I have no Check Engine Light, and no Airbag Light (both of them don't even light up at startup when I give contact with the ignition key). Not sure if they are even connected.
1JZ idles at steady 700rpm, runs nice and strong.
El-cheapo OBX-R boost gauge shows -15 in/HG vacuum at steady warmed-up idle.
Highest boost in 3rd, 4th and 5th is 8PSI, holds it rock solid.
Does the above sound right? I thought stock boost was 10-11PSI, like on the Supra? Maybe there is a vacuum leak under pressure...whats the best way to troubleshoot this?
PS Engine is running stock boost, only mods are FMIC, Blitz BOV, intake, Walbro pump and ACT 6-puck. Running straight exhaust too (stock mufflers), no cats.
Tach works perfect
#60
Tach works perfect
Tach works perfect
peter, i see you got your sn changed.... just like that tag huh? nice. thats gonna **** people off.
