A Few Questions for the 1JZ-GTE Owners
Well now that I have made the order for my 1JZGTE swap I am buying many other parts I need/want for the swap. I already have 2 spools of 20 gauge wire and such along with Apexi 60mm boost gauge & S-ACF II, XS MBC, us spec TT injectors with box, 255 lph fuel pump, Aeromotive FPR, and other little goodies, but I have a few questions on some other parts i need to order...
-Does the supra TT downpipe bolt up to the 1JZ exhuast manifold?
-Will a FMIC kit from a supra TT fit an SC with a 1JZ?
-Is it ok to run the factory radaitor? If not, which one should I use?
-WIll the upgraded aluminum uppper radaitor piping off the supra TT fit in a 1jz SC? If not, what hoses would I use?
-Can a use a supra TT Intake?
Originally Posted by RjRacing
-Does the supra TT downpipe bolt up to the 1JZ exhuast manifold? No, not without modification (if at all)
-Will a FMIC kit from a supra TT fit an SC with a 1JZ?Yes, but with modifications yet again. Why do that when you can buy a kit for the Soarer.
-Is it ok to run the factory radaitor? If not, which one should I use? Yes the stock one will be fine, just keep an eye on the top of it for any signs of cracking. If you wanted to run an aftermarket one you could get a Fluidyne, but you will also need a transmission cooler as the stock rad has that built in. *Edit, I noticed that you have a manual so no worries about the trans cooler then.
-WIll the upgraded aluminum uppper radaitor piping off the supra TT fit in a 1jz SC? If not, what hoses would I use?I do not belive that they will be suitable. You could just get some custom fabricated.
-Can a use a supra TT Intake? No, Again you can buy one specific to the Soarer.
Originally Posted by Gamer
What about down pipe?
Mortgage Slave
2. Might as well get an FMIC kit for a Soarer TT (Trust, HKS, ARC, Blitz to name a few)
3. I haven't heard of people blowing up the factory radiators (unless the top tanks haven't been changed (due to age), they usually don't give problems even with a dirty big frount mount)
4. You can get stainless steel piping for a 1JZ Soarer from Marlew Manufacturing here in Australia (www.lexussoarer.com)
5. I tried fitting an HKS pod filter (off a JZA80 Supra) onto my factory intake pipe and it wouldn't fit (I think there's around 5~10mm difference in diameter between the two).
Hope that helps you out.
Jose
No problem... It is a large box though so shipping will not be "cheap".
Good luck with whatever you choose.
I'm pretty sure this is a Supra cut, its a 1st gen 1jz as well
But look at the exhaust flange; looks identical to the 2jz as far as dimensions go
if this is correct, it'd be ****-easy to pick up a ebay downpipe for dirt cheap for a MKIV (which eliminates the stock cat and routes perfectly under a SC) and cut the flange and reweld in the correct clocked position
I'll post pics of supra downpipes so we can observe the difference
