Coolant Leak - Pics of source of the problem
Old 04-11-05, 07:44 AM
TMaxxTim
TMaxxTim's Avatar
Default Coolant Leak - Pics of source of the problem
Hey I've been losing coolant since I got my car but have never been able to figure out why. I always figured that the last owner didn't have the right coolant/water ratio and it was all boiling into the overflow tank, which it was for the mostpart, but I fixed that and I'm still losing coolant.
Here's 1 picture of where the coolant is leaking out of. What is this and does anything need to be done about it?
Attached Thumbnails Coolant Leak - Pics of source of the problem-dsc03503.jpg
Old 04-11-05, 07:45 AM
TMaxxTim
TMaxxTim's Avatar
I also have this layer of grease/oil all around under the cap and rotor and all the way down to the alternator. Is this just a valve cover gasket or something like this that needs to be replaced?
Attached Thumbnails Coolant Leak - Pics of source of the problem-dsc03504.jpg
Old 04-11-05, 09:56 AM
CleanSC
CleanSC's Avatar
Your water leak is at the water pump. Replace it.
Your oil leak is either your valve cover gaskets, or your distributor o-ring.
Old 04-11-05, 01:55 PM
/Aerostar\
/Aerostar\'s Avatar
Word, do both. The o-ring is like a half hour job, and then the valve cover gaskets are a few hours. Do it before your alternator gets soaked and goes out on you though!!!
Old 06-07-05, 01:49 PM
mikeloc24
mikeloc24's Avatar
I replaced my VC gaskets and the distributor o-ring and I STILL have oil/grease in that area. What else could it be?
Old 06-07-05, 01:54 PM
CleanSC
CleanSC's Avatar
Is it leaking thru the distributor itself? It has an internal seal that seldom goes bad. How's the inside of the dizzy look?
Take some carb cleaner and clean up the area and trace it back to the source. There's not much more that can leak on that corner assuming that the valve cover gaskets were installed correctly and the dizzy o-ring was the right one.
Old 06-08-05, 12:00 PM
mikeloc24
mikeloc24's Avatar
The dizzy and the little aluminum shelf that sits under it is clean...the grease/oil seems to come from under the left side of the timing cover and drips down onto the water pump...I'm starting to think this idiot mechanic installed the valve cover gaskets incorrectly...if that's possible...
Old 06-08-05, 12:06 PM
CleanSC
CleanSC's Avatar
What condition are the cam seals in?
Old 06-08-05, 12:14 PM
mikeloc24
mikeloc24's Avatar
dry as a bone. It's not coming from there...
Old 06-08-05, 12:23 PM
CleanSC
CleanSC's Avatar
Damn man I'm fresh out of ideas then.
Old 06-09-05, 10:41 AM
mikeloc24
mikeloc24's Avatar
I'm in the same place man. Nothing else I can do except tear into the top of the motor and try to find the source
Old 06-17-05, 07:01 PM
dejacky
dejacky's Avatar
Question
is taking it to another more reputable Lexus service shop an option?
Old 06-20-05, 12:10 PM
mikeloc24
mikeloc24's Avatar
Yeah, there's always more options.
Old 01-07-08, 09:53 AM
turbohye
turbohye's Avatar
Any news on the leak? A few of us are still experiencing a leak like this. Any finds?
thanks man
Old 01-07-08, 10:04 AM
sc250tt
sc250tt's Avatar
Umm.........This thread is 3 years old ....... think your a little too late but like clean sc said replace valve cover gaskets and o rings .Use silicone around cam areas and creases .If problem persist take it to a mechanic.
Quick Reply: Coolant Leak - Pics of source of the problem
