o2 simulator
Old 01-04-05, 04:26 PM
soarer479
soarer479's Avatar
Default o2 simulator
quick question for the NA-T guys will the o2 simulator for a 96+ supra fit in my o2sensor spot and wire in correctly? how many of you need the o2 simulator for your cars to run with out being way way way too rich to the point where it was throwing a maf code??
all this is obviously for the obd2 NA-T guys
thanks
Old 01-04-05, 04:43 PM
SPORTcoupe
SPORTcoupe's Avatar
O2 Simulators are garbage and if you use one for your main sensor (the one in the exhaust manifold) your car will soon be garbage as well.
The ECU changes determines fuel trim based on O2 sensor input.
If it's reading stoich at all times, the computer will think your car is running perfect and won't make any changes.
The only place you can use one of these simulated sensors with no harm is after the catalytic converter where the sensor just checks how well the cat is working.
~Alan
Old 01-04-05, 05:01 PM
soarer479
soarer479's Avatar
i have 2 sensors after the down pipe i need the o2 simulator after the dp but before the cat for my car to run properly i just need to know if the supra ones will fit....
Old 01-05-05, 09:17 AM
SPORTcoupe
SPORTcoupe's Avatar
If you have 2 sensors AFTER the downpipe, you have a pretty rare SC therefore I wouldn't know of any compatibility.
EDIT: As for the simulator...what do you mean by "fit"?
Are you asking whether the clips will match up, because even if they don't, you can just cut the wires and hardwire the simulator.
~Alan
JoeBlob
02-08-18 08:12 PM
GSRSRT
03-03-11 11:50 AM
zerosix
03-21-10 08:32 AM
shuiyuan
02-16-09 07:51 PM
CCC-TT
01-03-09 05:51 PM
Quick Reply: o2 simulator
