fuel_filter
Old 10-26-04, 05:15 PM
pilip99
pilip99's Avatar
Default fuel_filter
on the sc300, where is the fuel filter located at? I've heard it is underneath the driver side, but am not sure if I'm seeing it. Can anyone help out with this? Thanks
Old 10-26-04, 05:52 PM
/Aerostar\
/Aerostar\'s Avatar
Driver side, directly in front of the rear wheel well, on the underside of the car. Hard to miss
Old 10-26-04, 06:08 PM
pilip99
pilip99's Avatar
Thanks for the reply /Aerostar\
Old 10-27-04, 10:11 AM
mteele
mteele's Avatar
Get ready for one PITA install, hehe
Old 10-27-04, 11:15 AM
SPORTcoupe
SPORTcoupe's Avatar
Try to de-pressurize the lines as much as possible.
Take off the gas cap to relieve air pressure.
While the car is on, pull the EFI fuse....this will clear the lines of some more fuel.
Use clamps to pinch the lines shut either on both sides of the filter, or at least on the gas tank side.
**Make sure to remember to take the clamp off.
~Alan
Old 10-27-04, 02:12 PM
rscott
rscott's Avatar
~Alan
arent the lines hard lines? Clamping them off would damage the line and just lead to a costly replacement. Pulling the efi fuse and opening up the gas cap should be plenty to depressurize but there will still be fuel spilt so be ready with many rags and maybe something to let it drain into.
Old 10-27-04, 02:34 PM
pilip99
pilip99's Avatar
can anyone verify this before I try it? if its safe for the line?
Old 10-27-04, 02:41 PM
rscott
rscott's Avatar
depressurizing is a necessityor else fuel will spray everywhere. just dont clamp them.
Old 10-27-04, 03:32 PM
/Aerostar\
/Aerostar\'s Avatar
Yes make sure to dpressurize the line as much as you can. Look in the maintenance for a thread started by me about doing my fuel filter. Its a few pages long and worth the read
Old 10-27-04, 04:49 PM
SC300-95-TMM
SC300-95-TMM's Avatar
Yes somewhat true.
1) As for clamping lines -> helpful --on the semi-rigid line right out of bottom of tank
2) Removing fuse and venting tank - helpful if tank is pressurized. I kept mine in since under vacuum so it would not siphon too bad.
3) As for swap out, make sure you got a Rigid 10" pipe wrench handy. I had to wrench them on and off. Forget penetrating oil and the such. The SAE flare design is poor since the threads almost gall coming loose. Almost had to get a metric die to chase threads, but trusty Rigid saved the day. Filter good for another 100k. hehehhe Ohand the tank has a problem with siphoning fuel out QUICK!!! Just the way it was designed with a bottom feed line to the filter.
Old 10-28-04, 11:54 AM
SPORTcoupe
SPORTcoupe's Avatar
Nah. Trace the line to right around the axle and you shall see it turn to rubber (unless it's just in my 96 SC3)
Old 10-28-04, 12:53 PM
rscott
rscott's Avatar
Ah i was thinking directly around the filter. I didnt venture so far. That is good to know, but since mine is a 92 and the rubber is probably on its way out, ill probably stay away from the clamping. Wouldnt want that hose to crack.
Old 10-29-04, 02:45 AM
siaxazn
siaxazn's Avatar
its not as easy as it looks. be prepared for gallons of fuel to come out. Before i did mine i unplugged the fuel pump and cranked the car a few times to get most of the fuel out of the system. Then I clamped down the lines where they turn to rubber in front of the car. I read about this in a thread do a search. Even when i did that i still lost almost 2 gallons of fuel. My bucket was about to overflow by the time i finished the job.
The nuts down there are rusted up tight especially since our cars are old and its under the car exposed to the elements..I couldnt seam to get the nuts loose even with alot of liquid wrench and a flared nut wrench. After a while it started stripping the nut even with a perfect fit flared nut wrench so i ended up useing a vise grip to get it loose. if your mechanic could do it for cheap then i'd recommend you let him do the dirty work.
Old 10-29-04, 05:57 AM
CleanSC
CleanSC's Avatar
I wrote up a DIY step by step fuel filter change in this thread:
https://www.clublexus.com/forums/sho...hreadid=116905
The job blows. My arms burned for days.
Old 10-29-04, 12:41 PM
rscott
rscott's Avatar
nice write up.
There is definitely alot of fuel still in the lines. Depressurizing allows you to do the job without being sprayed with fuel in the eyes (maybe its not so extreme but it makes the job alot harder.
Quick Reply: fuel_filter
