Help ASAP: My 5-speed SC3 wont start
Alright, my car wont start. Its a 92 5-speed SC300. I discoveree this problem this morning when I tried to start my car as usual, but she wouldnt turn over. I tried several times and then took my moms car to work, then when I came back from work (8 hours later) I tried and tried again, and she doesnt turn on. Heres the problem: I depress the clutch all the way (as usual), and when I turn the key to start it, I hear this slight clickiung sound followed by a whirring sound (the starter??). I do not know what the problem is. I tried numerous times to start the car, with the clutch in, out, in gear, whatever. I also reset the ECU and checked the clutch switch (disconnected, visually checked, reconnected). Heres the thing, I almost got it to start once, but me being so used to turning the key off and on, I turned the car off before she was able to start . So, I need help ASAP, please, I need my car for work tomrorw.
Thank you
PS. I had this problem kinda when I first got the car. It would take a few tries before the car would start, but the problem eventually stopped. And now it is back
Thank you
Pray that your PS Pump hasn't leaked fluid all over your alternator causing it to short out. Based on your post it sounds like you were living on stored battery juice for the past couple of days, the alt perhaps hasn't been recharging the battery for sometime and the battery no longer has enough juice to start the car on it's own. Have you checked your PS Pump lately?
Alright, Im pretty sure its not the alternator, cause it has been replaced by the last owner 20k miles ago, also my PS pump isnt leaking at all. I have just checked the engine bay fuses, tapped the starter a few times, and also somewhat cleaned the battery terminals. She still does not start
Help
Thanks for your help
Help
it could actually be your starter. the contacts may be wear down on the inside. I had that problem also a while back. You turn the key and you get a click click sound. Then when it catches the engine turns over slowly.
Originally posted by /Aerostar\
Hmm, do you mean the battery terminals?
I have read in several previous threads that there is also a chance of the cable coming loose on the engine and ground side. check all of them.
Yea Im gonna go check all the wiring/connections/terminals as soon as it stops raining . If she still doesnt start, then Im spending my saturday workin on my car!! woooo
Alright, PROBLEM SOLVED!! WOOOOOOOOOOOOOOOOOO
It was both of the starter contacts. Not an incredibly easy job. If you have a 5speed SC3, this will make the job harder due to the clutch hydraulic systems on the tranny. If anybody needs info on rebuilding the starter, feel free to ask or PM me.
