SC300 Coolant Drain Plug?? Where it at?!
Im planning on flushing my coolant system out tomromrw and theres still a few things I still need to know. The most important being, where the hell is that drain plug for the engine?? I understand that the drain **** is at the bottom of the radiator and I will have to take off the underengine cover. Also, I bought some Prestone Super Flush, anyone have any eperience with this?
Ok thanks
Ok thanks
I asked the same question myself. People helped me and I got a rough idea where it was. Anyways, the drain bolt is near cylinder #6 which is in the back of the engine on the passenger's side. If you take a flashlight and look at the side of the engine behind the exhaust manifolds you'll probably see a rusted bolt that is probably a 14mm diameter.
Remember that it's near the exhaust manifolds on the side of the engine and it's in front of the transmission and if you put your head near the gas strut on the hood you'll see it. I hope this helps.
Oh and I used some kind of Prestone flushing agent. It's has the shape of the prestone coolant jug except it's 4 times smaller. When I poured it in, the inside of my radiator turned shiny.
Ok, I think I found it. It looks like its covered in something, maybe oil..maybe old coolant. It looks af if I remove it, the coolant would spill all over the exhaust manifold, or the pre-cat..whatever that thing is. So...when Im flushing my coolant, I remove the draincock and this little plug and let the coolant drain. Then fill up the radiator with water and flush it.
Is this right, thanks? Im going to put this off until tomorrow to be sure
Also...could a mod possibly move this to the maintenance forum?
evident
11-21-18 01:13 AM
