97+ SC300 Auto to Manual?
How hard would the conversion from a 97 automatic to a manual using a stock Lexus 5 speed transmission (From a 95)? I am assuming I will need:
Transmission
Axels
ECU
Driveshaft
All of the interior parts (pedals, trim, etc)
If there any reason why it won't work?
Transmission
Axels
ECU
Driveshaft
Re: 97+ SC300 Auto to Manual?
Transmission
Axels
ECU
Driveshaft
Transmission
Axels
ECU
Driveshaft
If you're thinking about boost, just get the auto built. Oh... the 5-speed pumpkin should be a direct replacement; consequently, axles aren't require, IMO.
You'll also need the following:
1) Tranny cross member brace.
2) Tranny mount
3) Slave cylinder
4) Gas peddle stopper to replace kickdown switch
5) 5-speed brake pedel rubber thingy (autos have a wider brake pedal)
6) 5-speed pumpkin
-scott
Chicago Lexus Club Moderator
Re: Re: 97+ SC300 Auto to Manual?
Originally posted by motorheaddown
No, it can be made to work. Hard?... no. Expensive?... probably (~$1500 parts/shipping + labor). Worth it?... I don't think so unless you just prefer a stick.
2) Tranny mount
3) Slave cylinder
6) 5-speed pumpkin
-scott
2) Tranny mount
3) Slave cylinder
6) 5-speed pumpkin
-scott
shifter assembly
shifter boot
shifter boot plate
clutch pedal assembly
clutch line
clutch master cylinder
manual transmission ECU
manual transmission brake pedal (not just the rubber thingy)
I am sure there is more but it's not that much expencive.
Chris
Harpo
Performance & Maintenance
07-10-19 04:22 AM
xsc2jz
06-26-12 02:31 PM
lowkeySC
SC400 / 300 Classifieds
11-16-09 09:18 PM
