WA-Looking for mechanic in Tacoma
Check engine light is on, had scan done at Autozone and Lexusof Tacoma and was told its a P0420 code and catalytic converter needs to be replaced. Dealer also told me that my cam seal is leaking and they recommended replacing timing belt while replacing cam seal. I had the timing belt and water pump replaced in October of 2015 in Miami so I'm trying to figure out if it makes sense to replace it again or just replace the cam seal. They want $846 to replace the cam seal or $1110 to replace cam seal, timing belt, water pump and drive belts.
