NX - 1st Gen (2015-2021)
corradoMR2's "Darth NX" Build Thread
Old 01-07-15, 06:09 PM
  #61
viperdoc
viperdoc's Avatar
Originally Posted by corradoMR2
In the US, have you tried Ace Alloy Wheels? "Convex" is the identical model to the Braelin BR-02. I haven't come across any other wheel company that custom bores their wheels to spec.
Thanks for the info. I looked at ace and for some reason a few wheels don't come in 19s whereas the same version in braelin do??? Weird. Anyway I like both the br01 and the br02. Since you owned both the RX f sport and now the nx, which do you think would look better on the rx? (I guess I should be asking this on the rx forum....sorry folks didn't mean to high jack this thread. But few folks on the rx thread do many mods on their cars).
Old 01-07-15, 07:08 PM
  #62
corradoMR2
The pursuit of F
corradoMR2's Avatar
Tough one since I'm biased towards the BR-02, even for the RX, because I like the 10 "blades" that make the wheel vs the 5-spoke "star" style wheel of the BR-01. But the 02 resembles the stock RX F-Sport wheel so if you're looking for a different look, the 01 is nice too.
PS. Open a new poll thread in the RX forum - I visit the RX forum still and I'm sure others will chime in.
Old 01-07-15, 07:25 PM
  #63
Received 2,753 Likes on 1,968 Posts
Originally Posted by Husker4the
Finally got a chance to sit in the F Sport today. They are REALLY bolstered. Even more than I anticipated. More than the IS for sure. Has me really concerned about overall comfort and comfort for larger passengers. I'm gonna have to do some more thinking. Hmmmm ... I'm certainly not extremely overweight but am wider across the hips (5'11" 195 lbs) than some and I'm not sure how I felt about them for myself. Anyone else care to chime in?
I'm 6' 205lbs and I found them snug, but comfortable. I have power bolsters in the GS and I set them fairly snug too. I'm a 42L suit jacket, so that will give you some idea of the size of my frame.
Old 01-08-15, 03:50 PM
  #64
Pei Mei
Pei Mei's Avatar
Corrado,
Can you tell me where you got the emblems for the center caps on your wheels? Thanks.
Old 01-08-15, 04:40 PM
  #65
corradoMR2
The pursuit of F
corradoMR2's Avatar
^^^ http://3dcarstickers.com/
Old 01-08-15, 05:19 PM
  #66
GrandSedanFan
GrandSedanFan's Avatar
Holy hell that looks awesome. I wish I could have gone whole hog on my RX when I had it.
Old 01-08-15, 05:27 PM
  #67
MerlinT
MerlinT's Avatar
It's too early to predict the behavior of the Paradas on potholes - I try to avoid them. But the road imperfections (no major potholes yet) I've encountered have been absorbed well from these tires and the NX as a whole (note I do have AVS). These specific tires are load rated (105) higher than the stock A/S tires (99). In addition, they are "XL" reinforced rated for relatively higher load/impact resistance. Also, remember, the Paradas are considered sport truck tires you also see mounted on 3 tonne Escalades so they are designed for the greater load and rolling resistance of SUVs as opposed to a higher performing touring or A/S performance tires for sedans and coupes.
Oh, and guess which tire the concept had?
Took them out on the first 2" snow fall this morning and snow traction was surefooted.
I have them on my RX350, for the last 3 summers, and I really like them. Excellent quality for the price
Old 01-09-15, 06:31 AM
  #68
Yuchan
Yuchan's Avatar
Wow, thanks for the tips!
Old 01-11-15, 12:22 PM
  #69
Pei Mei
Pei Mei's Avatar
Thank you!
Old 01-13-15, 11:30 AM
  #70
juvi22003
juvi22003's Avatar
Man that was fast lol, looks good tho...im sure if i got one i would be doing the same like i did with my 3IS. If you eventually do the springs and cover up some of that wheel gap that would be even more awesome.....
Old 02-22-15, 07:23 AM
  #71
alfaromeo3
alfaromeo3's Avatar
OP, did u get another set of tpms or used the oem ones?
Any warning tire pressure on the dash?
thanks!
Old 02-22-15, 08:02 AM
  #72
corradoMR2
The pursuit of F
corradoMR2's Avatar
thanks!
I used the OEM ones since at the time, there was a lack of clarity/availability from Lexus and aftermarket providers on which TPMS model works. In addition, I have no plans to use my second set of wheels (original OEM) and swap them for use as winters for instance.
With no TPMS, I believe you'd have at minimum the orange TPMS indicator on the dash, but I believe it will also monopolize the 4.2" TFT screen which I didn't want to take that chance.
Old 02-22-15, 08:31 AM
  #73
alfaromeo3
alfaromeo3's Avatar
^^^ thanks
since u did a square setup 20x8.5 et35, is there a little wiggle room in the rear to fit 9.5" or 10"?
i was thinking of 20x9 et40 and 20x10 et45.
Old 02-22-15, 10:11 AM
  #74
sapik
sapik's Avatar
^^^ thanks
Attention! these different eheels only for 2wd cars. For AWD is not good for the car electronics
I have AWD, I order the same wheels . I tested the wheel of my GS on NX and 10.5 is not problem
I have ordered Front 22/10,5/et 35 Rear 22/10,5/et 17 (Aimgain GIIM forged - Work wheels and Aimgain body ) my NX showcars only - 22" not is problem . I apologize for my language
Old 02-22-15, 12:41 PM
  #75
corradoMR2
The pursuit of F
corradoMR2's Avatar
^^^ thanks
sapik may be right about the staggered setup risking longer term issues with the AWD.
As for clearance between the suspension and the wheel, I have about 1 inch ( a little more at back) with my setup so for instance a square setup with 20x9 offset +40 will fit and should not rub if equipped like mine with 255/45/20s. As for this particular tire size, not it is slightly taller in diameter than OEM by 10 mm effectively "slowing down" the speedometer/odometer readings by 1.5% from reading with OEM 225/60/18 tires.
Quick Reply: corradoMR2's "Darth NX" Build Thread
