Review: switched to K&N performance air filter...
I dropped in a K&N air filter into the old NX on the recommendation of a friend. Hoping for better performance and more importantly better mpg.
I've been driving around for a day and I must say I do feel the extra power. I drive in eco mode most of the time and now eco mode feels like i'm driving in normal or sport mode. So it seems that the extra air the turbos are sucking down is helping. Where I feel the most increase in power is at low speed/rpm which is good cause it seems to minimize the turbo lag.
One negative I've noticed is that the car runs rougher. It's been the determined that the quality of the fuel makes a big difference in how smooth the engine runs and I'm guessing that the extra air going into the engine exacerbates the problem.
The pursuit of F
Thanks for the post. I tried once without any air filter for a couple miles and noticed the improved response. I also heard the release of air from the turbo's blow off valve which I did like. I would expect the free-flow filter you put in would do the same.
It would be unusual for a K&N filter to allow for more power. They really don't flow anymore air then a new OEM paper filter. The big plus is that the filter can be washed and reused dozens of times. I've tested them many times on a dyno in several cars and never was able to measure a difference beyond dyno margin of error.
I want to believe a K&N filter would flow slightly better, and maybe the turbo would make it even more useful still. After the whole point of forced induction is to add more air. Seems logical that any improvement in this area would help, but I would hesitate to get too excited about how much.
Allowing more air wouldn't make it run rough, though. The computer would adjust the mixture as required.
Keep the K&N only for the washability and reuse, but not for power.
placebo or butt dyno ROFL...
Research a little more on these K&N, yes they have more air, but with more air, comes more debris or particles that can and will harm your engine.
GL with your K&Ns, it's not worth it for me, just to clean them? you can buy any other filters and it won't break the bank when needing to change. jmo
Is it true that you have to buy a special K&N cleaning kit (even more extra cost) just to clean the filter?
K&N Air Filter - RIP OFF! - YouTube
The pursuit of F
I'm personally not a huge fan of K&N filters because of the maintenance and oils that could leak into your intake if not properly applied. BUT... I do have it in my RC F and am happy with the added sound and slightly better throttle response.
When cleaning, my local shop would charge $10 to clean the K&N filter, which I had them do when required. Hardly more then a bottle of cleaner and oil but I don't have to deal with it
Update: MPG is up significantly since installing the filter. About 0.4 mpg more according to the car's display. Which is significant considering I haven't reset the meter.
Thats great. Keep us informed. We rairely drive the car hard so improved power would not be noticed, but if the mileage improves significantly, that would be reason enough to try one on the NX.
Uh, in a small way, I agree w this guy! Probably not worth the time & effort if not in a "race" car! HOWEVER, you have to question him about the time he has to spend cleaning, drying & re-oiling the air filter when in the background he has a sowing machine & an iron unit? Really? Who does that anymore? And how much time do they take up?? Hahaha! I guess you have to have your priorities sometimes!!!
IS350atWOT
ES - 6th Gen (2013-2018)
14
04-02-13 11:38 AM
