NX - 1st Gen (2015-2021)
Lexus Handbook - 8AR-FTS Turbo Engine
Old 12-17-15, 01:44 AM
acheuk
acheuk's Avatar
Default Lexus Handbook - 8AR-FTS Turbo Engine
Describes the turbo components of this engine quite well. Good read if you have time.
http://www.natef.org/NATEF/media/NAT...exus-Turbo.pdf
Old 12-17-15, 04:04 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Awesome find and good read. Some interesting snippets below.
No surprises with this one as we've seen it in the Owner's Manual. Though the takeaway here is that if the tech handbook also emphasizes this, this procedure is important to follow and should not be ignored.
Lexus conservatism for the benefit of reliability...
Old 12-17-15, 04:26 AM
Swacer
Swacer's Avatar
I think they are a little careless with the use of psi, as psi by itself does not accurately describe the situation.
It should be rephrased to read as follows:
Therefore the technicians will see a target boost of close to 15psia (0 psig) when the vehicle is a idle. (This is because all the boost is going out the waste gate). This is normal condition, because atmospheric pressure is close to 15 psia (lookie, they use absolute here). During boost conditions under WOT, the target boost will reach approximately 30 psia, which means the ECM is requesting the maximum boost pressure of 17.4 psig from the turbocharger.
I think their bland use of psi causes issues.
Old 12-17-15, 10:33 AM
LexBob2
LexBob2's Avatar
This is some good information for someone who is considering the 2.0t and wants to learn more about turbo engines.
Old 12-17-15, 07:09 PM
NXOwner
NXOwner's Avatar
Location: Driving a UX Hybrid F-Sport! (in So California)
This is all they need to know...
Old 08-06-18, 02:57 AM
Raymond918
Raymond918's Avatar
I tried full throttle many times, but my turbo always under 1.5psi. Can someone tell me why? Or my ECU has a problem.
Old 08-06-18, 09:27 AM
ukrkoz
ukrkoz's Avatar
Oh, the fine print.... Referring to required idling time. Now, whatever goes wrong with those engines, it will be "you didn't follow the shut down procedure".
Old 08-06-18, 11:50 AM
no1SomeGuy
no1SomeGuy's Avatar
It's x10 ... so you're seeing 15psi, look closer.
Old 08-07-18, 03:37 PM
Raymond918
Raymond918's Avatar
yeah. 15psi? Is it normal?
Old 08-07-18, 06:47 PM
ching2
ching2's Avatar
This only opens to a website now. Perhaps somebody can upload the pdf? Thank you.
Old 08-31-19, 11:56 AM
DiverseIS
DiverseIS's Avatar
This is a really cool site I found. Show a complete diagram of the PCV system. https://toyota-club.net/files/faq/16...engine_eng.htm
Seize
10-19-16 06:56 PM
corradoMR2
12-17-15 02:09 PM
LexFather
10-17-08 02:36 PM
Quick Reply: Lexus Handbook - 8AR-FTS Turbo Engine
