Nebula Gray Pearl & Front License Plate
^^^ That looks great! You just made my decision even harder!
How difficult was the install? Did you have to drill holes? What is the range of the remote control?
Thanks for posting!
Thanks for posting!
Thanks! As you can see from the website that I posted, I did not get the remote control one. I'm sorry if the pictures that I took made it looked like it was. I only wanted to show you how the sliding mechanism works. Yes you will need to drill holes by the area where the lower bumper meets the under tray. It is a perfect spot for mounting because it's the only area sturdy enough.
Since I have the non-FSport I have to see what my undercarriage area looks like to see if this will fit.
Thanks again!
While I'm still debating the front license plate installation issue for my NX, I found a photo of a non-FS NX with the factory plate mount. Hmm...it doesn't look too bad...
So, I'm getting ready to mount my front license plate on my non-Fsport, non-hybrid NX 200t. I really don't want holes drilled in the front, which is what the OEM mount requires. Has anyone used zip-ties (cable ties) to hold the mount in place? If so, did you use it with the OEM mount or did you use another generic mount?
BigDog1011
05-12-14 06:29 PM
