View Poll Results: To what setting have you changed your NX Lane Change Signal Flashes?
Off
0%
3 times (the default, factory setting)
36.36%
4 times
9.09%
5 times
36.36%
6 times
0%
7 times
9.09%
I didn't know this could be changed!
9.09%
Voters: 22. You may not vote on this poll
Lane Change Signal Flashes is a feature that when you push the turn signal lever partway to signal a lane change, it will flash a fixed amount of times.
This is something the dealership (only) can change on your request [unless you have the special equipment to do this yourself].
The settings are as follows:
I, myself, had mine changed to "5 times". With the default of 3 times, I couldn't get over to the next freeway lane in time. 5 is just about right to where it stops as I'm finishing my lane transfer.
BTW, you can manually start the counter over by partially pushing the turn signal lever again in that direction. When doing so, the counter immediately starts counting from 1. If you want to stop the signal flashing before the number of times, simply push the level partially in the opposite direction.
The pursuit of F
I agree that 3 is too short, but I feel 4 might do. Will change it with the Carista app if and when it is ready for purchase with the TPMS programming feature...
The pursuit of F
Carista is working on this in their latest version and release is iminent. I'm expecting it to allow the user the ability to backup TPMS sensor codes and add new ones in the ECU such as a second set for some of us with a winter set of wheels. The ability to do this yourself will save time and $100+ at the dealer for every re-programming trip, twice a year, early winter and early spring when swapping back sets. See here for updates on this.
