NX - 1st Gen (2015-2021)
Correct Tire Pressure
Old 07-18-15, 04:45 PM
HappyUp
HappyUp's Avatar
Default Correct Tire Pressure
I have 235/55R18 tires on my new NX sport. The dealer put 37 PSI in all tires. The door indicates all tires should be 32 PSI. Car tires great, but might be a little bouncy. Being new, hard to compare to anything. Did the dealer over inflate? Should I put what is indicated on the car? Thanks.
Old 07-18-15, 05:01 PM
15RC350F
15RC350F's Avatar
Mine were the same, as were many of those who hang out here. I reduced mine to 33 PSI, which noticeably improved the ride. Probably lost an MPG or two as well, but such is life.
Old 07-18-15, 06:45 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Overinflation of tires is a common practice across all Lexus dealers. Even their loaner cars are high.
32 psi is recommended. You can go 2-3 psi below or above if you like depending on your comfort (less PSI) vs MPG (higher PSI) preference.
Old 07-19-15, 06:39 AM
ClaudeNX
ClaudeNX's Avatar
I am set at 33 and when driving at 60MPH they go to 36-7PSI and the ride is good
When I picked up from dealer they were set at 40PSI and up to 48 while driving and it was too much, creating a very rought ride
Old 07-19-15, 09:46 PM
jimque
jimque's Avatar
I set mine to 32 on cold tires as recommended on the door. The TPMS was showing 32 was too low. Tried resetting the system but the low pressure alert was still present. Had to up mine to 35. Anyone else experience this? Or know a fix?
Old 07-20-15, 02:44 AM
D4V1D
D4V1D's Avatar
This isn't normal. Sounds like a visit to the dealer may be in store for you. 32 PSI cold pressure is the target PSI on stock tires.
Old 07-20-15, 10:46 AM
olgzr
olgzr's Avatar
It's possible that your gauge is off and you were setting the pressure too low.
Old 07-20-15, 11:00 PM
jimque
jimque's Avatar
Ok, yeah I thought that was weird. The dealer had my tires set at 42, which is crazy. I'll get them to check it out.
Old 07-21-15, 02:16 AM
legrunt
legrunt's Avatar
If I am not mistaken, the manual states 41 psi if you are going to go over 160kmh. So thats what I have been putting into my tires...
Old 07-21-15, 07:32 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Oh no, that doesn't make any sense. At that speed, in hot weather, 41 psi (cold pressure) could hit 50-51 psi which is typically the max pressure a tire can handle and can blow out!
Please double check your manual and be safe!
Old 07-21-15, 07:52 PM
legrunt
legrunt's Avatar
I'll double check the manual tonight and post here...
But thanks for the concern bro...
Old 07-21-15, 08:08 PM
HappyUp
HappyUp's Avatar
Thanks for all the great feedback on this question. I brought my tires down to 33 according to my tire gauge. Much softer side. When I checked the cars dash screen that shows the tire pressure, it shows 34 in all. I'll assume the car's dash numbers are more accurate that my digital tire gauge. Also, why do Lexus dealers put so much pressure in the tires? Why do they see that as a positive?
Old 07-22-15, 04:05 AM
Swacer
Swacer's Avatar
The pressure in the tires seems to vary a lot between driving conditions. On a 58F morning, I can see 33psi in the tires and will get it up to 35psi by the time I get to work, but when its 80F in the afternoon it will be 37psi and will get to 39psi by the time I get home.
I think its the size of the tire, and the shear amount of rubber that causes so much variation in the pressure.
Honestly, I'm leaving it where it is. The ride is smooth and my tires are too new to show any type of wear that will allow me to adjust.
Old 07-22-15, 05:04 AM
RDLGX
RDLGX's Avatar
After putting back to 32psi, I find the ride much better. It does vary with temps lately with the hot weather....usually goes up to 35psi.
Old 07-22-15, 07:59 AM
My0gr81
My0gr81's Avatar
No, assume your guages are more accurate, specially if you are reading cold temp at rest when the car has been in the shade.
The TPMS sensors are inside the tires and are more affected by the internal air temperature. Also, there is no way to know the error margin for that particular sensor. Using an external guage to measure at cold temperature at rest in the shade and then using another one to confirm is the best way to ensure you have an accurate reading. If those 2 reading happen to coincide with the TPMS reading, then all the better. In my 2IS, I had one sensor on one of the tires that was off by 2psi. I know the tire was inflated properly, but it always read 2psi higher than it was. I mentally adjusted it every time I checked. Plus, I didn't have TPMS sensors in the winter wheels. so 5 months of the year my check tire light was on.
Quick Reply: Correct Tire Pressure
