OH Pioneer Premier GM-X432 Amp
Old 04-17-14, 04:46 PM
RDIS250AWD
RDIS250AWD's Avatar
Default Pioneer Premier GM-X432 Amp
Pretty much brand new had this for only about 3 months and I changed to a alpine set up.
Below are the specs. Serious buyers contact me at 9378385395
Asking $60 shipped within the US
http://www.pioneerelectronics.com/PU...ifiers/GM-X432
Specifications
Continuous Power (20Hz-20kHz, 0.08% THD)
2 ch: (4 Ohm ) 35Wx2
2 ch: (2 Ohm) 50Wx2
1 ch: (4 Ohm) 80Wx1
Maximum Power (EIAJ)
2 ch: (4 Ohm) 70Wx2
1 ch: (4 Ohm) 160Wx1
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion: 0.004% (1kHz, 4 Ohm)
Signal-to-Noise Ratio: 103dB (IHF-A Weighted, at 1kHz)
Dimensions: 8-1/8" x 2" x 6-7/8"
Features
Bridgeable 1/2/3 Channel Capability
PWM MOSFET Power Supply
Balanced Isolator Input Circuit
Gold-Plated Screw-Type Power/Ground Terminals
Gold-Plated Screw-Type Speaker Terminals
Gold-Plated RCA Inputs
Gold-Plated RCA Outputs (Full Range)
Hi-Volt Input Level Control (400mV-4.5V)
Gold-Plated Speaker Level Inputs
Selectable Crossover: 80Hz, -18dB/oct. (LPF) or 80Hz, -12dB/oct. (HPF)
Variable Bass Boost (40-120Hz, 0 to +12dB)
RDIS250AWD is offline
loveslexus
11-14-13 04:07 PM
Kohinoor
12-13-10 09:56 AM
lowKut
03-03-08 04:04 PM
kokopuffs4
08-16-07 07:46 AM
O. L. T.
03-21-03 04:26 PM
Quick Reply: OH Pioneer Premier GM-X432 Amp
