CA AUTOPAGE RS-1000 1Mile - HIGH END ALARM
Sold my SC400, never got around to installing the alarm on it. Miss it already :/ San Diego, CA. Paid 3** something. $250 o.b.o
6 Channel Alarm and Remote Car Starter with 5 on-board MICRO relays for parking lights, starter, accessories, ignition 1&2 and one additional relay / socket for starter disable.
· C3 Compatible with On-board Serial Port for AP Data Link Data Bus Integration
· Two-way paging receiver and transmitting remote with 3-color LCD screen using FM frequency bands for transmitting and receiving at 900 megahertz. Unit will transmit and receive up to 1 MILE. Unit also includes 24-hour clock with meter minder and temperature indicator and countdown run timer.
· New MANCHESTER CODE encoder.
· NEW STYLE Two-way, window mount SUPER EXTENDED RANGE transceiver antenna module.
· One 5-button extended range FM, standard 900-megahertz SLIDE COVER remote transmitter.
· SIS-11 Super Intelligent Sensor with dual stage shock / glass sensitivity.
· Discrete Temperature Sensor that communicates in-car temperature with LCD remote.
· Window-mount Knock Sensor for driver paging.
Plug-in super bright mini-BLUE LED and push-type valet/override switch.
TWO-WAY O.L.E.D. REMOTE OPERATION:
· 5-button configuration with selectable Button Lock to prevent accidental mis-use.
· Uses a rechargeable battery via Mini USB type connector w/ wall charger included.
· Battery life indicator and power save mode
· Full color (O.L.E.D. Organic Light Emitting Diode) with over 100 icons and animation screens.
· Optional Two Car Operation with LCD transmitter only
· Transmits on FM band and receives on FM band.
· 24-hour digital clock with count down timer for parking meter reminder. The clock doubles as a temperature indicator for monitoring in-car temperature. Displays in Fahrenheit or Celsius.
· Multiple audible confirmation tones as well as vibrator mode for paging.
2-way Transmitter Range Check Indicator
ALARM FEATURES:
· Six Channels of outputs (3 dedicated to lock/unlock, trunk and remote start / 3 auxiliary outputs)
· Dedicated function buttons on LCD remote and 4-button standard remote transmitter.
· Code learning / Anti-scan receiver with programmable code hopping.
· Back-up memory system
· Selectable Chirp Confirmation (OEM Style lock only chirp confirmation)
· Comfort Feature with OEM systems having key / remote control power window roll-up
· Dedicated remote panic and car locator
· Passive arming by-pass from the remote
· Parking light flash with dual polarity relay on-board
· Plug-in dual stage SIS-11shock sensor with sensor by-pass from the remote
· Starter disable output with relay and socket included
· Dome light illuminated entry output
· Dual polarity (+/-) door lock outputs with optional driver s door priority two step unlock
· Additional positive and negative inputs
· 500 mA grounded outputs for starter disable and door lock/unlock
· Programmable momentary, latched or timer on 3 auxiliary channels.
· Programmable manual / passive arming with true last door arming with auto re-arm on
· Programmable Single / Double Pulse Unlock (7 new timing adjustments)
· Programmable Parking lights (flash or constant)
· Programmable Pathway Illumination (on / off)
· Programmable voltage sense for delayed dome lights (on / off)
· Programmable horn and siren chirp delete
· Programmable ignition control lock and unlock
· Programmable pulse time for lock and unlock (.9 sec. / 3 sec.)
REMOTE CAR STARTER FEATURES:
· 5 On-Board Relays:
Ignition 1
Ignition 2
Starter
Accessory
Parking Light
· 3rd Ignition (-) output
· Dedicated Second Start wire
· Dedicated Ground out when running
· GM- Non starter wire timing compatible
· Ground when start (-) output
· New Turbo Timer feature
· 2nd Accessory (-) output
· Selectable one or two push Safety Start
· Programmable gasoline or diesel with 10, 15, or 20 second Wait-to-Start
· Hood pin switch safety input (pin switch included)
· Selectable RPM / Voltage Start
· RPM / Voltage / Hi-Low level check
· Timer control start option
· Sensor control output during start
· Temporary Stop Feature
· Factory Alarm Disarm and Rearm signal output
· Programmable factory keyless door locking before and after start
· Programmable start status output with shock sensor bypass
· 45 second door / dome light bypass after ignition is turned off.
· Programmable Ignition 2 (on / off)
· Programmable 3 hour timer start
· Programmable 1 / 3 hour timer start
· Selectable Run Timer (5/10/20/30 minutes)
· Selectable Gasoline / diesel
Selectable Diesel warm-up time
ALARM FEATURES:
Ignition 1
Ignition 2
Starter
Accessory
Parking Light
