NY F/s 2 12 polk audio db1222
SELLING MY USED POLK AUDO DB1222 FOR $160 FIRM, JUST A COUPLE OF MINOR SCRATCHES ON THE EXTERIOR, NO DAMAGE AT ALL. TEXT ME AT 917-488-9003. LOCAL PICK UP ONLY AT NYC AREA
db1222 Features:
Huge power handling 720 Watts continuous and 1500 Watts peak!
Front loaded slot port provides thunderous bass and allows greater air displacement then round port designs.
Extensively braced trapezoidal MDF enclosure eliminates performance-robbing box flex. dB1222 is 32-inches W x 14-inches H x 15-inches D at the top and 18-inches D at the bottom and weighs 88 lbs.
Nickel plated heavy duty input terminals accommodate speaker wire up to 8 AWG or twisted pairs of 12 AWG.
Viscoelastic isolation damping between the baffle and cabinet prevent any unwanted vibrations or buzzes when the subwoofer is driven hard.
Rugged automotive grade black carpet provides an attractive and durable enclosure finish.
Heavy duty automotive grade ABS grilles provide awesome looks but also protection for the woofers.
Paintable grilles and baffle looks great as is, or may be matched to your vehicle's color.
2 ohm impedance uses subwoofer amplifier power most effectively.
Klippel optimized components using a state-of-the-art Klippel distortion analyzer, Polk engineers were able to optimize the woofer's motor structure, voice coil alignment and suspension for the best possible performance, even at extreme listening levels.
Dynamic Balance® composite woofer cones feature tremendous stiffness-to-mass ratio. Lower mass means faster transients and finer detail.
High-roll santoprene rubber surrounds provides reliability in the temperature extremes of a vehicle.
Fire retardant NOMEX® inner suspension increases reliability while providing extended cone travel.
SPECS
Subwoofer
Quantity 2
Diameter 12" (30.48cm)
Type Dynamic Balance driver with poly-composite cone
Electrical
Total Frequency Response 27-200 Hz
Nominal Impedance 2 ohms
Efficiency 103 dB
Power Handling
Continuous 720 watts
Peak 1440 watts
Recommended Amplifier Power 50-1000 watts per channel
Subwoofer Box Dimensions
Dimensions
Height 14 3/4" (37.47cm)
Width 32 1/2" (82.55cm)
Depth 18 1/2" (46.99cm)
db1222 Features:
SPECS
Subwoofer
Quantity 2
Electrical
Efficiency 103 dB
Power Handling
Peak 1440 watts
Dimensions
Punky
10-05-15 05:31 PM
BSC300TT
10-31-10 10:15 AM
