MA FS Pioneer Premire amp/ JBL comp Sub
For Sale is My Pioneer Premier 1600W mono Block Amp in mint condition as well as 12" JBL P1224 Sub. Took it out of my SC for weight reasons. Sound was amazing very clean and has the adjustibility to be VERY loud.
Asking 140$ for the Amp
120$ for the Sub
JBL Sub Specs:
# 12" subwoofer with dual 4-ohm voice coils
# Kevlar-impregnated paper cone with Hi-roll rubber surround
# Plus One cone design for more effective surface area
# power range: 50-400 RMS watts (200 watts per coil)
# 1600 watts peak power handling
# frequency response: 23-450 Hz
# sensitivity: 94 dB
# mounting depth: 6-13/16"
# sealed box volume: 1.00 cu. ft.
# ported box volume: 1.75 cu. ft.
Pioneer Premire specs:
* Competition SPL Digital Mono Amplifier with 2000 Watts Max. Power
* Peak Music Power 2000 Watts
* Load Impedance Capability: 2~8 Ohm
* Continuous Power (4 ohm): 500 Watts x 1
* Continuous Power (2 ohm): 1000 Watts x 1
* Total Harmonic Distortion: 0.05%
* Signal-to-Noise Ratio: 90dB
* Bridgeable
* Class-D Design
* PWM Regulated MOSFET Power Supply
* MOSFET Output Section
* Screw-Type Speaker Terminals
* Balanced Isolator Input Circuit
* 2 Channel RCA Inputs Gold
* RCA Outputs (Pass Thru)
* Input Level Control Hi-Volt (200mV ~ 6.5v)
* Built-in Crossover Selectable LPF
* Dimensions 10-3/16" x 2-1/16" x 9-13/16"
120$ for the Sub
JBL Sub Specs:
* Bridgeable
* Class-D Design
Last edited by SC51; 02-26-11 at 09:22 AM. Reason: Admin wanted me to remove craiglist link
KayGee
12-31-14 09:39 AM
questnyc
05-13-10 10:21 PM
Seize
07-19-07 03:24 AM
