TX BNIB Focal Power Limited Edition FP 2.75 2 Channel Amplifier
I have a Focal Power 'LE' FP 2.75 for sale. The regular version is black and the LE is the gunmetal version. This is absolutely brand new. The birth sheet shows this particular amp does 77.3w rms.
$350 shipped
Nominal Power: 13.8V continuously @ 4 Ohms 2x75W RMS
13.8V continuously @ 2 Ohms 2x100W RMS
Bridged Power: 13.8V continuously @ 4 Ohms 1x200W RMS
Signal/noise ratio >100dB (A)
Damping factor at 4 >500
Frequency response (±1dB) 10Hz-35Hz
Input impedance 13k
Input sensitivity 0.2-5V
Variable high-pass filter crossover 50-150Hz (12dB/oct.)
Variable low-pass cossover 50-150Hz (12dB/oct.)
Dimensions (HxWxD) 50x230x280mm (2x9x11“)
Weight 3.10kg (6.83 lb)
$350 shipped
Input impedance 13k
Bump for you always having high quality audio for sale and being a good seller. I finally got around to installing the Focal 6w4255 6.5" mids I bought from you and they sound awesome with my setup.
