Brand New Elemental Designs NINe.5 Amp
Price
350.00
Contact information
racinstylez@aol.com or 7133068971
Is the item new or used
New
Product description
Up for sale is a Brand new Elemental Designs NINe.5 Amp. I bought this amp for a project, and will no longer be using it. I paid $500 for it, and never even took it out of the box. My loss is your gain.
Model Name : NINe.5 Amplifier
Large 5 Channel Car Audio Amplifier
RMS Power @ 12.5v : Front Channels
4 x 100 @ 4Ohm @ 0.05%THD
4 x 55 @ 8Ohm @ 0.05%THD
4 x 175 @ 2Ohm @ 0.05%THD
2 x 350 @ 4Ohm @ 0.05%THD
RMS Power (Subwoofer Channel) @ 12.5v :
1 x 250w @ 4Ohm @ 0.09%THD
1 x 450w @ 2Ohm @ 0.09%THD
1 x 600w @ 1Ohm @ 0.09%THD
Amplifier Specifications
1 x 600w @ 1ohm (Sub Channel)
4 x 175w+ 1 x 450w @2Ohm
4 x 100w + 1 x 250w @ 4Ohm
Height : 2.25
Width : 10.25
Length : 25.5
Detailed Amplifier Specifications
Signal to Noise Ratio > 100dBA
Variable Input Sensitivity .3 - 8V
Remote Variable Input Sensitivity No
Variable Low Pass X-Over 50Hz - 4KHz
Current & Thermal Protection Yes
Remote Bass Equalization Yes
Variable Phase Control Yes
Master / Slave Option No
Efficiency
Variable SubSonic Filter N/A
Fuse(s) External 1 x 120
Max Current Draw 280
Damping Factor > 300
Warranty 1 Year
* 3 Level Inputs Individual inputs for 3 channels are integrated into the NINe.5 amplifier. 2 front channels and the independent subwoofer channel.
* 0Awg Capable Such a beast of amplifier requires a beast of a connection. The NINe.5 amplifier comes out of the box ready to fit wire as large as 0/1 eNETIC cable.
* Adaptive Input The NINe.5 input section allows you to use inputs from 1 channel or 3 channels selectable externally right on the amplifier.
* HP/LP/BP Crossovers Included The NINe.5 features a unique crossover to it's design. Full Low Pass / High Pass / Bandpass capability on all 4 front channels @ a 18dB slope. Ranging from 50Hz to 4KHz it gives you a fantastic range of control for the most demanding systems
* 2 Stage Protection Circuit The NINe.5 protection circuit design is unique in it’s integration isolating the front and rear channels independently from one another. If your driving one part of the amplifier too hard it’s active communication system protects the entire amplifier. The front 4 channels and 5th subwoofer channel are independently protected.
* Dedicated Subwoofer Channel Crossover The subwoofer crossover section ranges from 40Hz - 100hz @ 18dB w/ very simple toggle On/Off switch allowing you to use the onboard crossover or digital X/O from your head unit.
* Easy Connections The NINe.5 features very simple connections on all channels. Fully housed connections protect one another while increasing speed and reliability of installation.
350.00
Contact information
New
Product description
Height : 2.25
Width : 10.25
Length : 25.5
Efficiency
Warranty 1 Year
saelee39
01-09-09 11:35 AM
