FS: Kenwood KAC-6201 2 Channel Amp
This Kenwod KAC-6201 is in great condition! Its a great 2 channel amp and a great system starter. Works well with a sub (bridgeable) or with components etc. I'm asking for $60 shipped. Check out the pictures as well as the specifications below:
General Features
- Extruded Aluminum Heat Sink: with Sandblast Finish
- Power Indicator: Red Logo Triangle
Power Ratings
- Bridged Power Output at 14.4V (1kHz, 0.8% THD): 150 Watts x 1
- Maximum Output Power: 350 Watts
- Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 75 Watts x 2
- Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 60 Watts x 2
Audio Features
- 2 or 1 Channels of Amplification
- Ground Isolation Circuit
- High-Pass Electronic Crossover: 150Hz, 12dB/oct (Switchable)
- Low-Pass Electronic Crossover: 80Hz, 12dB/oct (Selectable)
- Quiet Turn-On
- RCA Audio Inputs: Gold-Plated
- Speaker Connectors: Screw-Type
- Speaker Level Input Terminals: Screw-Type
- Stereo, Mono, or Tri-Mode Operation
Power Supply Features
- 2-Ohm Stable
- Copper EE-Core Power Transformer
- Noise Supression Filter: Toroidal
- Power Input Terminals: Screw-Type
- Power MOSFET Switching Power Supply
- Power Supply Fuse: 25A
- Secondary Capacitors: 2
Pictures of the amp in its current condition:
General Features
Power Ratings
Audio Features
- Quiet Turn-On
- 2-Ohm Stable
