FS : JL Audio components + coax + Amp
Up for sale are my beloved JL audio XR650-CSI Component speakers, along with JL audio XR650-CXI coaxials + my JL audio e4300 4 channel amp, beautiful quality sound, only 2 months old....deciding to work on something more powerful.
JL audio XR650-CSI
Product Description:
When you set out to build the very best, you work with only the best. That's why XR component woofers are built with suspensions and cones from the world's best manufacturer of such parts: Dr. Kurt Muller and Co. These parts are expensive, but they also represent the best the world has to offer and are integral to the incredible sonic quality and consistency of the XR products.
The long-throw component woofer features a mineral-filled, polypropylene cone body with a butyl rubber surround and a highly optimized motor system, delivering stunning midbass impact and midrange quality.
The tweeter is a neodymium magnet, ferrofluid-cooled, 1-inch (25mm) aluminum dome with a synthetic rubber surround that damps unwanted ringing for smooth, non-fatiguing output. The component tweeter features JL AUDIO's exclusive RSR mounting system, permitting precise alignment after installation for optimum performance.
High-end, programmable crossover networks with premium polypropylene capacitors, premium inductors and solid-state tweeter protection round out the package. Crossover networks can be programmed to 15 possible settings (3 midrange presence settings, 5 tweeter level settings). The crossover networks are attractively presented in a smoked acrylic case that complements any installation.
This exceptional component system will recalibrate your reference standard for automotive sound.
JL audio XR650-CSI
Features:
Description: 2-way System: 6.5-inch (160 mm) Woofer; 1-inch (25 mm) Aluminum Dome Tweeter, Grilles Included
Power Handling: 70W Continuous
Recommended Amp Power: 25 - 150 Watts
Efficiency: 89.5 dB @ 1W/1m
Frequency Response: 48 Hz - 25 KHz ± 3 dB
Frame Dimensions: 165.5 mm
Grille Tray Dimensions: 171.4 mm
Magnet Diameter:: 82 mm
Frontal Grille Protrusion: 21.2
Xmax: 2.5 mm
JL AUDIO e4300 amp
Class AB 4-Channel Amplifier
Absolute Symmetry Class AB Circuit
Differential, Noise Cancelling Input Topology: RCA jack inputs(low-level) and multi-pin jack(high-level)
On-board crossover: State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50-200 Hz. Configurable as Low-Pass or High-Pass
Preamp Output: Pass-through type
CEA-2006 Compliant
RMS Power Rating (14.4V):
4 ohms: 70 watts x 4 chan.
2 ohms: 110 watts x 4 chan.
Bridged (4 ohms): 220 watts x 2 chan.
Bridged (8 ohms): 140 watts x 2 chan.
RMS Power Rating (12.5V):
4 ohms: 45 watts x 4 chan.
2 ohms: 75 watts x 4 chan.
Bridged (4 ohms): 150 watts x 2 chan.
Bridged (8 ohms): 90 watts x 2 chan.
Frequency Response: 10 - 25kHz
Damping Factor: >200 @ 4 Ohms / 50Hz, >100 at 2 Ohms/50Hz
S/N Ratio: >104 dB referred to rated power(A-weighted, 20Hz-20kHz noise bandwidth)
Input Range: 200mV - 8V RMS
Bass EQ: +6dB Fixed Frequency, Fixed 'Q' with port for optional remote bass control
Slew Rate: +- 22V/us
Dimensions: 13.8" L x 9.25" W x 2.36" H
1-year Sonic Electronix warranty
Amplifier Specifications:
Number of Channels 4
RMS Power (4 ohms) 45 watts x 4 chan.
RMS Power (2 ohms) 75 watts x 4 chan.
RMS Power (1 ohm) Not Stable
Bridged RMS Power 150 watts x 2 chan.
Peak Power Output 880 watts approx.
Min. Impedance Unbridged 2 ohms
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power 0.08%
Speaker Level Inputs Yes
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover HP (50 - 200Hz), LP(50 - 200Hz)
High-Pass Crossover N/A
Low-Pass Crossover N/A
Subsonic Filter N/A
Signal-to-Noise Ratio >104dB
Channel Separation N/A
Bass Boost Yes, 0 - 6 dB
Bass/Gain Remote N/A
Fan Cooled No
Fuse Rating 40A
you'll also get the XR series COAX speakers.
6-1/2" Evolution Series Coaxials
70 Watts Continuous Power Handaling
Mineral-filled Polyproplene Cone
Butyl Rubber Surround
Low-Profile Symetrical Roll Spider
Ferrite Magnet
Recomended Amp Power: 25 - 150 Watts
Sensitivity: 92.5 dB
Impedence: 4 Ohms
Frequency Responce 48 Hz - 25 KHz
Tweeter
1" Aluminum Dome with Soft, Synthetic Rubber Suspension
Ferrofluid Cooling / Damping
Neodymium Magnet
Angle Swivel Mount System
Programable Crossover
High-Grade Mylar Capacitors
High-Grade Air-Core Inductors
1sr Order Low-Pass Filter
2nd Order Low-Pass Filter
3-Position Adjustable Tweeter Level
Mid-Range Presence
Speaker Specifications:
Speaker Size 6-1/2"
Design 2-Way
Sensitivity 92.5 dB
Frequency Response 48 Hz - 25 kHz
Peak Power Handling 150 watts
RMS Power Handling 70 watts
Impedance 4 Ohms
Top Mount Depth 2.8" (71.4 mm)
Bottom-mount depth N/A
Cutout Dimensions N/A
i encourage you guys to throw me some reasonable offers, id like to get rid of this asap.
PRICE REDUCED!!!!! $700.00 i paid 950.00 for this, have receipt.... system has experienced very light use in the 2 months it has been installed. EVERYTHING is in mint condition, very good price for a brand name audio system.
JL audio XR650-CSI
JL audio XR650-CSI
Features:
Xmax: 2.5 mm
JL AUDIO e4300 amp
CEA-2006 Compliant
Subsonic Filter N/A
Fan Cooled No
Fuse Rating 40A
Ferrite Magnet
Impedence: 4 Ohms
Tweeter
Neodymium Magnet
Mid-Range Presence
Speaker Size 6-1/2"
Design 2-Way
Sensitivity 92.5 dB
Impedance 4 Ohms
ok, here's the breakdown....
JL audio XR650-CSI component speakers = $350
JL audio XR650-CXI Coaxial speakers = $200
JL audio e4300 amplifier = $225
if you buy the Components + the Coaxials from me.... ill throw in the amp for 50 dollars.
Priced to sell = 600 + shipping.
FIRM. that's all folks.
Originally Posted by Lexbox
Any more price drops coming soon? You can buy them brand new for the same price. You gotta love Ebay.
Automan
01-16-11 04:46 PM
lg300
02-07-05 11:48 PM
Hameed
13
03-10-04 04:22 AM
